Circle D - Multi Disk
Old May 14, 2009 | 08:52 AM
  #21
Circle-D's Avatar
Former Vendor
Originally Posted by stock48
Very nice looking! What OD'' is this converter, and how does it hold big TQ in a 5000LB 4x4? Im looking for something that will drop to at least 4500RPM on a 5500RPM shift unlocked.
The billet front will fit either a 245MM, 258MM or a 265MM converter. So I can build it to fit just about any setup. 500HP to 1500HP. A 1000 RPM drop on a shift extension will probably be a 245MM, but it depends on the power and setup. Shoot me a PM with your mods and I will come up with a plan.
Chris
Old May 18, 2009 | 08:23 AM
  #22
Circle-D's Avatar
Former Vendor
A friendly bump for the day!
Chris
Old May 18, 2009 | 10:01 PM
  #23
silver-mod-o's Avatar
Hunt&Fisherator
a well deserved bump for the evening This converter in person is a BEAST, no two ways about it.
Thanks once again for your hospitality and tour today Chris.
Old May 19, 2009 | 10:43 AM
  #24
moregrip's Avatar
what a rush!
Originally Posted by moregrip
How does Circle D compare to a PI converter?
Circle D????? Can you please compare your converter to a PI for me? What advantages would I have to switch?
Old May 19, 2009 | 11:00 AM
  #25
LaSinister's Avatar
I have a 2000 5.3L Silvy, full bolt ons and a TSP 220/220 @ 111 LSA. This
set up is N/A set up, no n2o. I am shoping for a tq converter.
What torque converter would you recommend from your product line?
Old May 19, 2009 | 11:34 AM
  #26
Circle-D's Avatar
Former Vendor
PI is the originator of the billet fronts and multi disk setup, at least as far as I know. They have a nice multi disk setup. I actually buy some of my parts from them. So they are definitely good competition. I decided I wanted to build a multi disk that can stand up to extreme HP. I think I came up with a design that is very impressive. When you see it in person, the decision is very easy.
You mentioned "switch". I assume you already have a multi disk PI. If you are not having any lock up slippage and happy with the stall, then I think you are fine.
Hope this answers your question.
Chris
Old May 19, 2009 | 11:51 AM
  #27
Circle-D's Avatar
Former Vendor
Stock 4L60E I presume. It depends on what you are looking for and your budget. Want to go set some records, towing capacity, street manors?
Option 1 - 278mm 11" 3000-3200 stall. Good performance and great street manors. Still tow as well.
Option 2 - -258MM Billet option. Can be a single disk or a multi. Multi better if you plan on towing. Great performance and good street manors. Stall choices from 2800-3500.
Chris
Old May 19, 2009 | 09:57 PM
  #28
quicksilverado's Avatar
Which converter did you end up getting?
Old May 20, 2009 | 12:30 AM
  #29
moregrip's Avatar
what a rush!
Chris
So far I like it ok, although it has yet to lockup, the stall seems about right. We'll see. I do like the 6 bolt vs 3 bolt arrangement though
Old May 23, 2009 | 01:01 PM
  #30
Circle-D's Avatar
Former Vendor
Bump for the weekend.
Chris
