Originally Posted by AKlowriderZ71
(Post 4998005)
If it's not tuned for the 'verter, don't be surprised if it throws a shift solenoid DTC and defaults to 3rd gear only when you do try a WOT launch. Also, if you stand on it while it's defaulted to 3rd gear, you might smoke your trans.
Just a heads up. :) |
Originally Posted by whitedakota
(Post 4998022)
Installed my fresh rebuilt tranny last Friday with circle d 3200, hd2, servos etc.. Checked the fluid and put a new tune on the truck. Several wot runs, 4 hi launches adjusting shift points, timing, and fuel.. Took it to the drag strip the same night for test and tune and cut 2.12, 2.18, 2.16 60 ft times in my heavy crew cab! Hasn't missed a beat! Another very very satisfied customer here also!
V1 |
A buddy of mine did the tuning. He uses hp tuners. 10 years experience in tuning. I haven't bought a camshaft yet. I had stock48 spec that cam for a tvs1900. But I recently purchased a set of tsp 2.5 heads with 1518 springs (10,xxxmiles) for $400. My buddy put his truck back to stock. I'm thinking of having them milled .030 and going with a tsp 220 on a 112. Still undecided for now!
I didnt break mine in, got fluid level right and then went and beat on it
love it but wish I had more stall |
(Post 4998082)
Originally Posted by GREENSIERRA
(Post 4998213)
Break in is only for the lock up clutches.
Chris nailed the converter in my former Camaro. Told him I wanted the best of both worlds (n/a & bottle). Circle D 4C 3800 flashed 3750 n/a and 4200 on the bottle. 60' improved .12 n/a and .10 on the bottle and gained 2-3 mph on the big end vs Vigilante 2800. I was still dialing in the suspension shooting for a 1.3x when the track closed. My best 60' was a 1.42 with 3600# raceweight on a stock 10 bolt. I'm sure it helped that I knew the weight and power that I was making n/a and on the bottle. I will be a return customer with my next project. |
Originally Posted by Velocity1
(Post 4998271)
Your comment about wishing you had more stall is probably the most common one. I may get to beat mine this weekend if the rain quits. Compared to stock is an appreciable difference. Too bad nobody makes a trans brake for a 60E, lol! Might help sensationalize the holeshot a little:burn:
Well matted the gas pedal tonight. Wow. And I'm running the stock tune corrected for speedo compensation only. Tanked up with high test 93 tune goes back in tomorrow. Between the new FP regulator and the converter alone it's a runner. Can't wait to data log, adjust the LTFT's and PE and reload it. Can't imagine how much better a truck like this can be with a custom tune, larger valve heads, some more compression, TP 220 and headers. Unfortunately for my bank account I'll probably get to find out.
(Post 4998271)
