Circle D - 278mm 3200
Old Nov 29, 2009 | 12:47 PM
  #31
Circle-D's Avatar
Former Vendor
Originally Posted by scotthughes
265/75/16 tires and 3.73 gears is what i have. any ideas what the cruise at?
I would guestimate a sub 2000 RPM, maybe right at 2000, cruise for your specs. Looking forward to your order -
Chris
Old Nov 29, 2009 | 12:53 PM
  #32
Circle-D's Avatar
Former Vendor
Originally Posted by greenz71
Hey Chris, how does this converter tow? I will almost never tow more than 4000lbs, but couple of times a month will do 2500lbs. Will it be ok with a trans cooler?
I have quite a few guys towing with the 278mm and it works great. It uses the 12" clutch, so when you get to lock up it is plenty strong. So just get a cooler like you mentioned to keep the temps down while not in lock up and you will be good to go. Under 200° is good, but under 180° is preferred.
Chris
Old Nov 29, 2009 | 11:51 PM
  #33
Z'06's Avatar
Chris,
What's your max recommended stall on this TC for towing with a 5.3L Tahoe? And does changing the cam afterwards (but keeping the cam mild) affect your recommendation?
Thanks!
Old Nov 30, 2009 | 06:57 AM
  #34
Circle-D's Avatar
Former Vendor
Originally Posted by Z'06
Chris,
Thanks!
There is not a definite answer. Depends on what you are wanting out of a converter. I have a lot of guys with the 3000 that tow quite often. They have big coolers to make sure the temps never get high. I also have a few guys that like a 2500 for their towing/performance truck. I think you will be fine with a 3000 for most towing needs. If you use it for work and tow just about every day and towing a couple tons, then might step down to the 2500 or even leave it stock. Hope this helps some.
Chris
Old Dec 10, 2009 | 08:03 AM
  #35
mean94lt1's Avatar
12 Second Club
pm sent this might be my next mod
Old Dec 10, 2009 | 08:33 AM
  #36
SILVERBIRCH's Avatar
^^^ you are gonna love it Im really loving mine thanks Chris
Old Dec 10, 2009 | 05:03 PM
  #37
ss454327's Avatar
Just another praise for the 278mm stall. My 60' went from a best of 2.06 with the stock stall to 1.83 with the Circle-D. Also my shifts only drop 1500 between shifts instead of 2k. There is no way I would look past this stall...it's by far the most bang for your buck.
Old Dec 10, 2009 | 08:17 PM
  #38
03chevyroyce's Avatar
circle D FTW!!!!! i love my 3C!!
Old Dec 10, 2009 | 10:03 PM
  #39
budhayes3's Avatar
PT's Slowest Truck
Mine's a 2A multi-disc...can't wait to see what it feels like
Old Dec 21, 2009 | 06:35 AM
  #40
Circle-D's Avatar
Former Vendor
Bump for the day - Great converter great price.
Chris
