Chevy lean question.
Old 07-15-2015, 08:26 PM
signguy62's Avatar
Default Chevy lean question.
I just removed the factory 2" blocks. Replaced all the hardware (u-bolts, saddles, etc.) Before I removed the blocks there was maybe a 1/2" difference between left and right rear. Now there is better than 1" difference and there is less fuel in the tank now than when I removed the blocks. What would cause the Chevy lean to get worse? I did de-crank the keys up front also. But would that affect the rear lean? The front is pretty level.
Old 07-15-2015, 10:19 PM
1bad2k's Avatar
I would bet it is from decranking the bars. Supposedly the "lean" originates from the front of the vehicle. Make small adjustments and run it around the block each time in between. I did this and got mine a lot closer to level.
Old 07-15-2015, 11:51 PM
terravast4's Avatar
I have a 3/5 drop and noticed the lean a lot after lowering. i raised the driver side leaf shackle a notch and it completely took away the lean and leveled both front and rear
Old 07-16-2015, 12:14 AM
1bad2k's Avatar
There was tsb and they even sell the part now that is a about 1/4 to 3/8" thick that goes between the leaf spring and perch. I have heard this works well sort of like what terravast4 mentioned. Just remembered about that....
Old 07-16-2015, 05:39 PM
signguy62's Avatar
Thanks! Come to think of it, the key adjustment bolts weren't set the same when I started. I'll hold off messing with them for now. I've got 1-3" drop keys and 2" shackles on the way.
Old 07-16-2015, 05:43 PM
signguy62's Avatar
Thanks! Once the new keys and shackles are installed I'll fine tune with the key adjustments and shackles.
Your trucks stance is killer! Maybe just a tad too low for me. What parts did you use for the 3-5 drop?
madmann26
04-29-2020 09:17 AM
Pimpinpete
43
12-22-2017 08:13 AM
03sierraslt
14
10-09-2015 05:53 AM
BlownHD
10-03-2015 12:24 PM
02AWDAWSDenali
10-01-2015 05:08 PM
Quick Reply: Chevy lean question.
