"chevy lean"
Old Feb 20, 2011 | 03:52 PM
TURBHOE's Avatar
The autoride air package is all new. Nothing changed with it's install. I askthe same question.
This is a coil sprung suspension so no leaf fix will work for this tahoe.
But I will have him try some of the coil ideas. I think the best thing would be to swap springs from left to right. If the lean is still there then there is more going on than springs. I will try the body and frame measurements also.
Old Feb 20, 2011 | 04:37 PM
oldred95's Avatar
Oh yea forgot about it being coil springs on the rear. Sounds like a plan swapping sides. I second measuring at the frame too. For whatever reason my left rear fender height measures 1/2 inch lower than the right rear but measuring off the frame the truck is perfectly level side to side. Nothing is bent, out of shape, damaged, or even looks like its off, but measuring it by the fenders something is up with the left rear bed side yet the fit and finish is still perfect. Its weird but go off the frame and you should be good.
Old Dec 13, 2011 | 06:51 PM
DCogswell's Avatar
Originally Posted by 1bad2k
X2. I literally did this about 3 weeks ago. My truck had a serious lean to the drivers side in the rear. I bought the GM parts spacer which is about 1/2" thick and longer u bolts from gmpartsdirect dot com for $25 shipped and now my truck sits perfectly level. Being an suv with the 4 link rear, that isnt an option for you. I would just google like a **** lol, for someone who has fixed this issue.
I read somewhere about someone that was working for GM to straighten out frames bc when the trucks are shipped they are strapped down in the rear only on the drivers side and they have the lean from the get-go because of this. Not sure on that thought.
Do you have the part numbers for the items you bought from gmparts?
Old Dec 13, 2011 | 07:38 PM
03regcab sierra's Avatar
My 04 had a 1" lean when I bought it. The previous owner had taken the passenger side overload out to level it. Talk about some terrible axle hop!! I had a spare overload I put in it thats when I noticed it lean. I just finished installing a 3-5 drop on it now the lean is gone. Still have both overloads in didnt shim anything either. bugged the crap out of me at first!
slimchevy2
Oct 4, 2015 08:02 PM
BlownHD
Oct 3, 2015 12:24 PM
Rockrz
Sep 29, 2015 09:07 AM
jamesm32
Sep 24, 2015 11:49 AM
Glenn98ZM6
Sep 18, 2015 07:31 PM
