changing broken front coil spring
Old Apr 14, 2009 | 07:29 AM
1blueSS's Avatar
formerly 1fstrst (11/25/2010)
Default changing broken front coil spring
Hey! So I'm changing out both of my front coil springs (because the driver side broke) Anyway I've already ordered a set of belltech 2" drop coils and rented the spring compressor.I was just wondering if their is anything I should be aware of or any little tricks you all might know. I've never done this before it looks pretty straight forward just wondering.
Thanks Jeff
05 silverado 2wd
Old Apr 14, 2009 | 09:08 AM
chevytruckguy's Avatar
With a 2" drop coil spring you probably won't need the compresser to get them in. The stock coil can be dropped out easily by removing the lower control arm bolts while supporting the control arm with a jack. Make sure the frame is supported by jackstands. Then lower the arm out and the coil will just fall out. You might have to pry out the unbroken coil. The broken coil will be easy. If you're not doing a spindle, it saves you from having to break the ball joint loose and possibly tearing the ball joint boot.
Old Apr 14, 2009 | 11:13 AM
1blueSS's Avatar
Cool thanks. The ones that im replacing are 2' drop coils as well. So you don't need to take out the bolts that hold the shock it all just drops when you lower the control arm?
Old Apr 14, 2009 | 11:29 AM
2 tone 02's Avatar
No, you need to remove the shocks first! What brand coils did you have and what are you replacing them with?
Old Apr 14, 2009 | 03:30 PM
1blueSS's Avatar
I have a 2" ground force and I'm going with a 2" belltech
lsxmalibu
Jul 29, 2015 07:08 AM
Slammed96
Jul 27, 2015 07:22 AM
4B11T
Jul 13, 2015 03:48 PM
