Can't use my LPW Diff cover
Old May 22, 2007 | 08:14 PM
budhayes3's Avatar
PT's Slowest Truck
Man that sucks...good to know though, as I have a similar diff cover and was hoping to someday get a rear sway bar. If I remember correctly, creederado used to have a TA rear diff cover and sway bar...not 100% sure though. (he may have had a Hotckis bar)
Old May 22, 2007 | 08:21 PM
dewmanshu's Avatar
Moderately Differentiated
Yeah Holty's works fine and his is a Hotckis bar. Sucks, f-ing sucks. I am gonna see if I can find a way to put extension brackets on the sway ends . If not, I guess torch and hammer here i come. FWIW the LPW website does warn you of this. LOL
Old May 22, 2007 | 09:16 PM
TurboGibbs's Avatar
Ownage.
Old May 22, 2007 | 09:27 PM
dewmanshu's Avatar
Originally Posted by TurboGibbs
Ownage.
owned? yeppers...
Old May 22, 2007 | 09:33 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
F'n Dewey!
Old May 22, 2007 | 09:43 PM
2004SSS's Avatar
why not sell it and get a jegs or ta girdle?
Old May 23, 2007 | 07:45 AM
Holty's Avatar
Notorious BIG
OWNED! LMAO, those pics are f'n halarious!
Old May 23, 2007 | 08:07 AM
dewmanshu's Avatar
I don't know. Haven't thought of that yet.
Old May 23, 2007 | 09:07 AM
ColtSteele's Avatar
I was just thinking this! You think this will replace the operation of the sway bar?
Unfortunately the sway bar and the axle tube brace are for different uses.
This is from LPW's site;
The LPW Axle-Tube Brace eliminates case distortion on any width rear end by preventing forward movement of the housing tube ends. Additional stress on bearings, axles and suspension components is also relieved, further ensuring correct wheel alignment. Maintaining proper wheel alignment increases performance and provides even tire wear. Each side of the LPW Axle-Tube Brace is independently adjustable using high-quality, right- and left-hand rod ends.
Pretty trick looking set up though don't you think
Old Sep 27, 2007 | 10:11 AM
dewmanshu's Avatar
Once on the ground there is plenty of room. Just on the lift you have to sink those studs and it still hits, just barely though.
