cal tracs set up pre load
Old Jun 10, 2008 | 09:11 PM
2004SSS's Avatar
Default cal tracs set up pre load
im finally going to test out the cal tracs friday and i cant find the instructions or any helpful info on setting up the pre load to set them up for use at the track with drag radials.
any help?
Old Jun 10, 2008 | 10:10 PM
Superado's Avatar
11 Second Truck Club
General Installation Guide:
Originally Posted by Calvert Racing
Installing the CALTRACS is very straightforward. Raise and support the car high enough to remove the rear tires. Allow adequate working space. Next, the rear spring assemblies should be removed. This will facilitate replacement of the front eye bushings. Support the rear end housing in place while the springs are out. This will eliminate the need to disconnect the drive shaft, brake lines etc. Press or have pressed, the original front eye bushing out of each spring assembly. Replace these with the machined aluminum CALTRACS bushings supplied in the kit. Now, reinstall the rear springs into the car.
With each spring assembly ready to go in, position the forward pivot assembly to the front spring eye. (Assure that the Spring Stop Bolt is located on the upper surface of the spring.) Install the Steel Bushing through the pivot and front spring eye bushing. Now, reinstall the spring using the original hardware. Repeat the process for the other side.
Lower the rear axle assembly on to the springs. Install the supplied spring perches as you would the stock items being replaced. Attach the shocks.
Now the Force Transfer Link can be installed by starting the HEX (wrenching) end on to the forward rod end. Remove the rear rod end from the spring perch and start its threads into the rear Force Transfer Link. Adjust the assembly to proper length by holding the rear rod end then rotating the Force Transfer Link until the rear rod end will line up with the mounting hole in the rear spring perch. Install the rear rod end fastener and secure.
With the CALTRACS installed and the rear tires reinstalled, lower the car to the ground and put the drivers weight in the car be sure there is no pre-load on the bars. As an initial setting, turn the Force Transfer Link until the spring Stop Bolt just contacts the upper surface of the spring, then turn the Force Transfer Link one quarter turn more to establish pre-load. Tighten the Force Transfer Link lock nut. That's it!
Old Jun 11, 2008 | 07:49 AM
fossil's Avatar
11 Second Club
I have shims for my rearend. I adjust tell the cross bar touches my leaf springs and then I back off a half a turn. With preload on mine, it rides like crap driving around. With the adjustment my 60' are 1.60's.
Old Jun 11, 2008 | 08:42 AM
Superado's Avatar
yeah I found some other interesting reads on the subject last night:
http://www.yellowbullet.com/forum/sh...d.php?p=794830
more good reading:
http://www.yellowbullet.com/forum/sh...ad.php?t=48463
http://forums.performanceyears.com/f...d.php?t=536039
http://www.google.com/search?hl=en&s...reload&spell=1
Old Jun 11, 2008 | 08:45 AM
Superado's Avatar
in this article,
http://www.fordmuscle.com/forums/all...endations.html
a guy mentions running the CalTracs on top of the leafs instead of underneath as designed...commenting that it hits the tires alot harder that way...
a local fabricator here makes something very similar to the CalTracs that mounts on top of the leafs as well...he has had alot of success with them on Dodge trucks...
Oobray
Jun 13, 2022 03:38 AM
nickpc82
Aug 30, 2015 09:18 PM
Sexyrado327
Aug 2, 2015 04:08 PM
Ketis
Jul 23, 2015 12:37 PM
