Cal Trac Owners Come on In ????
Old 01-27-2006, 08:55 AM
ranwalk's Avatar
MR Marine, Could you tell us how you adjust yours? I still dont have mine where I am happy and when I start messing with them I end up making the truck want to go sideways when it breaks loose instead of straight. You running any preload on them or slightly loose? I would like to hear anything you can offer as far as advice on setting them up. You seem to know whats up with them, pulling 1.3 60ft times
Thanks,
Randy
Old 01-27-2006, 01:36 PM
Blaze5509's Avatar
I am down for a nor-cal track meet whenever possible. I am itchin to get my truck to the track so I can get some baseline "stock" #'s.
I have been curious about the caltracs on a 4/6 flip also.
Old 01-27-2006, 05:22 PM
TURBO8's Avatar
Sac is open on saturdays test and tune I was going to go the last two saturdays but it was raining. I herd that sears is open one sunday a month. I think I am down for sears, it's alittle closer for me.
Old 01-27-2006, 05:23 PM
TURBO8's Avatar
check there website first.
Old 01-27-2006, 08:03 PM
MR Marine's Avatar
Thanks,
Randy
You will have to experiment with them , but I run 0 preload on drivers and 3 flats on the passenger with the shocks set at 9 drivers 8 passenger to make it go straight.
Old 01-27-2006, 08:42 PM
TOTM: January 2007
Last Call's Avatar
I will start a thread in the Western section and see if we can get some people to go to Sears, closer for me too. I want to run my truck when the temps are cool.
Old 01-27-2006, 11:42 PM
As soon as I get my truck ready I'll be down to go too. I'm in Vallejo so Sears is close to me also.
Old 01-28-2006, 04:30 PM
greentahoe's Avatar
How do these work? Are they beneficial when you are running around on crap street tires (285/50/20 GT2's) or are these only beneficial when you are running a slick or drag radial?
Old 01-28-2006, 05:09 PM
TurboGibbs's Avatar
They are basically a bolt on ladder bar. They help with any tire.
Old 01-29-2006, 06:44 PM
TheBrett's Avatar
Default great experience w/ my CalTrac bars
i have a set on my 1982 backhalved S-10. it has a Ford 9 inch with lowered springs. i still had to use 3 inch lowering blocks to get the *** down some but everything fits fine even with a 15 inch rim. you just want to make sure the bottom of the cal-trac is not lower than the wheel rim level. if it is & you lose tire pressure it will dig into the ground & you could lose control.
no they are not hard to adjust.....just loosen a lock nut & rotate the chromoly link bar.
no welding involved if they are the right ones for your application.
when i drove my s-10 for the first time it was all the difference in the world. it felt like it was on rails.
Quick Reply: Cal Trac Owners Come on In ????
