C1500 Front Spring Install
Old May 6, 2005 | 11:47 AM
Default C1500 Front Spring Install
Has anyone installed a front lowering spring, I've done them on cars and we always separated the lower ball joint from the spindla to release the lower control arm and then slipped in a spring compressor or lowered the lowered the control arm down slowly with a floor jacket. When I check the GM Service Manual they show that unbolt the 2 mount bolts on the control arm and they have a special tool that you can support both side with a floor jack and lower it down that way
Any suggestion would be appreciated thanks.
Old May 6, 2005 | 12:34 PM
joesilver01's Avatar
When I first did mine I also replaced spindles too so I guess this wont be much help. But I removed uppper and lower nuts on ball joints to remove spindle unbolted the shock and everything slid right out and the just placed the new coil back in.
Slammed96
Jul 27, 2015 07:22 AM
Ammadien
Jul 22, 2015 08:50 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
black6spdz
Jul 16, 2015 01:32 AM
07NBSChevy
20
Jul 8, 2015 07:27 PM
