Is a C-Notch recommended with a 2/4 drop?
Old Dec 15, 2008 | 08:38 PM
BlackGMC's Avatar
Resident Retard
Default Is a C-Notch recommended with a 2/4 drop?
I just ordered my 2/4 (it's a Belltech, springs front, hangers/shackles in back) and I was wondering if a C-notch is recommended? I have 2 friends with a 2/4 drops and if i remember correctly both would hit the frame in the back... I only have a few days to install the drop and new sway bars(addco front and back), after that it will probably be months before I get to do anything to the truck again due to work and fiance moving in ... So i want to do it all at once... Let me know your experiences with your 2/4 drop...
Thanks...
Old Dec 15, 2008 | 08:42 PM
lawazita's Avatar
no.....u dont need a c notch with that drop. thats the first drop i did 2 my nnbs, then a went with the 4/6, and then with the 5/7 and i still dont hit the frame nor have any issues.
Old Dec 15, 2008 | 08:47 PM
BlackGMC's Avatar
Resident Retard
Are you talking about a NNBS or NBS? Mine is a NBS, I noticed your sig pic was of a NBBS
Old Dec 15, 2008 | 08:51 PM
outlawz2004's Avatar
I had a 3/5 and it surely needed a notch(sitting on the lowered bumpstops), raised it an inch in the rear and it really could have used one still, but was not nearly as bad. Put any amount of weight back there and your riding the bumpstops. If I lowered mine again, it would definetly have a small notch.
Old Dec 15, 2008 | 08:52 PM
skyhighsami's Avatar
no title here
Notch for 6 inches. 4 inches you will be fine
Old Dec 15, 2008 | 08:54 PM
00ChevyScott's Avatar
Wearin' da big hat
Lurius needs a C-notch on his 3-4 drop.
I'd do it anyways.
No ****, its cause you're a NNBS. He's not.
Old Dec 15, 2008 | 08:56 PM
Sleeper Bowtie's Avatar
I have a 2/4 drop on my rcsb and it hits the frame. Its not bad with no weight in the bed but once you put anything in the bed, mine hits alot.
Old Dec 15, 2008 | 09:04 PM
BlackGMC's Avatar
Resident Retard
Well i read alot of threads on here, some say yes, some say no... So i just said screw it and ordered one... Better to be safe than fitting frame....
I got a McGaughy's C-notch, seems sturdy enough!!! I plan on bolting and welding it in....
Old Dec 15, 2008 | 09:29 PM
charcold-bowtie's Avatar
I say yes. Would ride a lot more friendly in the back....
Old Dec 15, 2008 | 09:39 PM
blue2003ls's Avatar
You have chosen wisely. The NBS suspension does not leave alot of room between the axle and the frame with the 4" rear drop. You could probably do without but you would hate yourself every time you hit the frame on a big dip or bump. I don't know if welding the notch is really that much better. Hopefully someone else will chime in but I think the heat does something to the metal in the newer frames but that could be total BS.
