Build 4L60E or 4L80E?
Figured a 4L80E would be the best route and as far as future plans right now I'm just thinking a stall and near future a supercharger. Not sure if I wanna get to crazy with it.
If I had the time, 4L80E right off the bat, pretty easy to swap,gotta cut and extend your cross member, put two pins in the harness I think and swap over the rear yoke off a 2500 so you can use your stock drive shaft??? I thought there was a sticky on here some where.
Didn't the 80's have a different internal gear ratio too? longer first gear?
I am going to buy a built one from a guy in sherman pretty soon. The damn T/C is what gets you on the 80e, ther are about $800-$1k then theres the shaft upgrade... my 80e, T/C, speed balanced steel shaft and swap is going to rune me about $3,000 alone. But its worth it.
I should have done an 80e from the get go.
