breakin period on a level 7 flt 4l65
Old Jul 5, 2011 | 08:29 PM
ou812sm's Avatar
Default breakin period on a level 7 flt 4l65
What's the breakin period on this I just got mine installed
Old Jul 6, 2011 | 03:00 AM
06Sierra2's Avatar
Break in period? I would just run it till its warm, check the fluid and go through a few easy part throttle shifts to make sure everything is fine and then mash on the gas!
Old Jul 6, 2011 | 06:32 AM
AndysC3's Avatar
if your installing a new torque converter there's about a 500 mile brake in period. Each manufacture has a specific brake in procedure. Just give em a call and they will let you know.
Old Jul 6, 2011 | 07:24 AM
built408's Avatar
I would ask FLT, every builder has their preference.
Personally I would just double check the fluid, shift through the gears a couple of times, and go for it.
Old Jul 6, 2011 | 10:44 AM
ou812sm's Avatar
Hey guy I'm lovin this transmission it shift perfect fast and firm if your getting on it it gets firmer its just awesome
Old Jul 6, 2011 | 03:31 PM
Andy @ FLT's Avatar
Banned
Thanks! Glad to hear all is well.
Old Jul 6, 2011 | 04:47 PM
ou812sm's Avatar
Andy you guys are awesome at flt a1 service thank you
Old Jul 6, 2011 | 05:12 PM
ou812sm's Avatar
Hey I want to give a shout out to circle d and to Chris at circle d the torque converter OS setup just as I asked thank you
Old Jul 6, 2011 | 06:43 PM
budhayes3's Avatar
PT's Slowest Truck
Which converter did you go with?
I installed my FLT Level7 and Circle-D 258mm 2B billet multi-disc a little over a year ago, and I remember that I was told to take it easy for 500 miles...then at 501, I let er rip! I believe that besides converter break-in, you want to allow the frictions in the trans to seat and wear in properly without excessive heat and glazing.
Speaking of excessive heat...hope that you installed a decent trans cooler along with that nice expensive new combo...gotta protect your investment!
Old Jul 6, 2011 | 08:01 PM
ou812sm's Avatar
The torque converter I got from circle d is
4l60 ls pro series stage III 258 2c and it rips I actually installed it 2 and half months ago the tranny I had only last a month behind my new tq and new engine setup all I need to do is get it tuned right
