Brakestand gone bad!
GFYS and STFU
Originally Posted by VTODD
yes, rev up to a bit over 4.5k or so and dump that clutch and immediatly, and i mean immediatly, slam on the brake and just play a balancing act from there. you will know what i mean once you do one. the goal is to keep the tires spinning, the rpms up and your truck planted in the same spot until you want to slowly release on the brake (SLOWLY) and glide forward. you will understand once you play with it a bit.
if you get too addicted to this, you will be investing in an aftermarket clutche
It's possible you spun the tires a little bit but the clutch started slipping/burning.
My moms Toyota feared me when i was 15 haha....
First time it ever burnt the clutch not the tires like you stated the smeel lasted a good while it drove funny.
Finally it was ok again......except i had taken alot of life out of the clutch and about 5k miles later it had to be replaced.
If you try to do a brake stand again and the clutch slips again you need a new one for sure.
let the clutch out fast . . . as if you're power shifting from 1 to 2 and you're trying to get a 2nd gear scratch. If you're trying to power break, you don't want to slip the clutch at all.
Heres a burnout gone bad
http://videos.streetfire.net/categor...3401761599.htm
if it doesnt work switch to mediaplayer
lukn4trbl355
Oct 21, 2015 11:19 PM
...******' A brother....a must for a manual tranny smoke fest!
