Best 4L65E parts?
So im sure theres a million threads on this already, but im building my 65 and i was looking for a list of the best parts to put in them. My pump broke so i want to put a nice pump in it in addition to everything else. Let me know whats the best!!! Thanks guys
The Sawp is not any more than a fully built 4L65E is going to run. Even if you build it yourself. The 4L65E requires alot of expensive internal parts.
Everyone has a different opinion on what works in these transmissions. Take a look at some of the top builder list of parts. At least the ones that have a list on there site.
Here is FLT's list
Level 7
Media blast case, bell housing, and tail housing to restore a new aluminum finish. Prep case for assembly
300M billet input shaft
300M billet output shaft
Sonnax Smart Tech Housing
Sonnax Smart Shell
FLT performance pump (Includes billet pump rotor)
FLT (billet 6061 aluminum) overrun piston
GM 5 pinion input carrier
GM 5 pinion reaction carrier
Bearing style reaction shaft
New reverse input drum
Alto wide 2-4 kevlar lined band with reinforced anchor
B/W hi-energy 3-4 clutch pack
HD extra wide double caged 29 element sprag
4L65 low roller clutch
Sonnax Super Hold 2nd Servo
Sonnax Super Hold 4th Servo
Bushing kit
New solenoids
New spacer plate
B/W clutches
Seal & gasket kit
Filter
Updated aluminum accumulator pistons
FLT calibrated valve body w/ HD 2-3 shift valve modification
Set end play to FLT specs
Case cooler fittings
Here is RPM transmissions.
All of our LEVEL X 4L60E/4L65E/4L70E automatic transmissions include:
*Media blast transmission case
*RPM Level V 3-4 clutch pack
*RPM reinforced sunshell with collar and bearing
*Heavy Duty double caged 29 element sprag
*4L65E low roller clutch
*Billet 4th gear servo
*Transgo HD-2 shift kit
*Corvette Servo
*Wide 2-4 band
*Updated aluminum accumulator piston
*Bushing kit
*New shift solenoids
*New GM valve body spacer plate
*Seal & gasket kit
*GM Filter
*RPM Spec clutch and band clearances
*RPM sleeved input drum
*Billet over-run piston
*GM 5 pinion planetary gearsets - front and rear
*NEW Extra WIDE Heavy Duty double caged 29 element sprag
*300m Billet output shaft
*4L65/70E low roller clutch
*Billet 2nd gear servo
*300M Billet Input shaft
*Billet Pump Rotor
*Billet Forward Piston
*2-3 HD Apply Valve
*QUICK TIME SFI Approved Bellhousing
*Deep Aluminum pan
*Micropolished Internal Parts
*Sonnax Smart Tech Input Drum
*Cryogenic Processing by Performance Metal
*Each transmission is dyno-tested before shipping
Here is FLT's list
Level 7
Sonnax Smart Shell
Bushing kit
New solenoids
New spacer plate
B/W clutches
Seal & gasket kit
Filter
*Corvette Servo
*Wide 2-4 band
*Bushing kit
*Seal & gasket kit
*GM Filter
*Billet Pump Rotor
*2-3 HD Apply Valve
*Deep Aluminum pan
