Axle/Brake swap questions
Old Jun 21, 2012 | 08:38 AM
jvoisel's Avatar
Default Axle/Brake swap questions
Do drum brakes and disc brakes mount the same to the axle?
Buddy has a 99 and 06 silverado, wants to swap the axles out since the 99 has a built rear but wants to keep the brakes on the truck as they are. So question is, can we take the brakes off of each axle and mount them to the other, or do they mount up differently?
Old Jun 22, 2012 | 07:33 PM
pdxmatt's Avatar
Axle flanges are the same.
Old Jun 22, 2012 | 08:28 PM
1FastBrick's Avatar
Custm2500's Rude Friend
They mount up the same but the flanges are clocked differently. It shouldn't affect braking. Just make sure you bleed them good.
Old Jun 29, 2012 | 03:23 AM
slowec's Avatar
https://www.performancetrucks.net/fo...esults-503963/
Old Jun 29, 2012 | 07:37 AM
jvoisel's Avatar
Thanks. Looks much easier than I thought
Old Jun 29, 2012 | 11:15 AM
boo5ted's Avatar
Wait wut?
I know this is noob question but what about just swapping entire rears ends? Would braking performance suffer on either truck due to the disk/drum difference?
Old Jun 29, 2012 | 11:23 AM
jvoisel's Avatar
In that thread going from disk to drum wasnt a problem but not sure about drum to disk, I thought I had read something about the valving being different/wrong but I'm not really sure, someone else will chime in I'm sure
Old Jun 29, 2012 | 11:25 AM
boo5ted's Avatar
Wait wut?
That's what I was thinking. If it doesn't hurt performance it would be a lot less work to just swap the entire thing.
Old Jun 29, 2012 | 11:32 AM
jvoisel's Avatar
Your 06s Drums will stop better than the 99s discs
Not sure how much though. May not be too noticeable, especially since all you haul around is two purple car seats
Old Jun 29, 2012 | 12:25 PM
boo5ted's Avatar
Wait wut?
Actually if you want to get technical one is purple because it has an LSU cover on it, the other has yellow and tan flowers.
What I'm more concerned about is the disk setup on the rear of the 06 and the truck still stopping in acceptable distance.
