Auto ride
Old Sep 2, 2011 | 07:57 PM
Yukon04's Avatar
Default Auto ride
Curious as to where the fuse for the auto ride compressor is, also wondering if there's a way to change Te height setting mine is set really high in the rear
Old Sep 3, 2011 | 07:21 PM
Suburbazine's Avatar
Changing the height is a pain in the behind on Autoride. You can modify the wiring at the compressor and add switches, but then it drives the computer nuts up front. I think Autoride is connected to one of the STUD fuses- been a while since I looked.
If it's low in the back and the compressor isn't working, it's not unlikely you blew a bag and the compressor subsequently died from overrun and water buildup.
Old Sep 6, 2011 | 02:49 PM
Gordy M's Avatar
I just replaced my compressor and motor and rebuilt the dryer with the Arnott motor. Pretty easy solution. To adjust the height, it is located on the frame before the rear brakes.
SloSVO
Nov 22, 2020 07:34 PM
dsbodley
Nov 14, 2015 09:46 PM
Rockrz
Sep 29, 2015 09:07 AM
dantheman1540
14
Sep 28, 2015 09:22 PM
Closer_2001
Sep 24, 2015 09:15 PM
