Auburn Pro not locking so great any more
#21
As for the pic, that truck was fulltime 4x4 with a rear LSD. That driveway was on a hill and was very slimy (was raining too). I slipped off the right side while taking the turn and the end result was I pushed the whole front end off the driveway. It took a rollback an hour to free it since the line of approach was so narrow, the tow truck slipped off the side of the driveway and got stuck too. Wound up getting both of them out with a tractor.
It would have been much easier if the truck had a locker instead of an LSD, it only had one front tire and one rear tire that would turn, both of which were the useless ones.
#22
No offense, but if you took your best 1/4 and mine, and equalized weight between your full blown racetruck and my essentially stock truck on 20s up front, you would have at best, a 0.5 second difference. I've got a pile of timeslips and a couple pounds of caked rubber on my bedsides to show that the trutrac gets the job done for my application and hasn't given a simple wimper, despite twisting a hardened aftermarket axle and snapping DS in half.
So basically what your saying is that if you put my motor in your truck it would run within .05 of what you currently have? No offense, but thats stupid.
#23
I just think the clutch type is better, thats all.
#24
A little brake apply will get both wheels going. But stick one wheel on concrete and one in the mud and see what happens, no amount of brake apply will make both wheels spin.
If I were doing real offroading I would probably look into a different type of setup. E or air locking type.
For snow and dirt roads in the dc area, the trutrac is probably enough for me.
#26
Furdkiller
11
Nov 8, 2018 09:04 AM
07NBSChevy
Mar 16, 2016 05:41 PM
