ATF? Synthetic or not?
Old Apr 17, 2008 | 06:59 PM
03sierraslt's Avatar
Default ATF? Synthetic or not?
Well my tranny is out and apart, as of right now when it goes back together I am going to be running Amsoil Synthetic. Who is running sythetic ATF? I know the new GM fluid is Syn. but I have never personally used it. Whats everyones take on this? Thanks.
Old Apr 17, 2008 | 07:16 PM
LBSBLOWN's Avatar
I have been running the AMSOIL Supershift synth. in both my supercharged trucks with great luck, My Magnason side-mount supercharged Suburban has been running the Supershift fluid for 85,000 miles and still shifts hard and have had no Trany problems (Stock Trans except for HPTuners tweeking)
I have run the Supershift in my Radix bolwn Sierra for 36,000 miles with no problems (stock trans except for Transco shift kit and servos and HPTuners tweeking) I change the fluid every 30,000 miles.
Old Apr 17, 2008 | 07:35 PM
Well when I pulled the pan the oil came out looking great. I am not pulling it because its broke but to build it up before it breaks. However it has lived this long boosted with only a shiftkit, servos, and HPT tweeking.
Old Apr 18, 2008 | 04:19 AM
??? Anyone else
Old Apr 18, 2008 | 09:31 AM
Wilde Racing's Avatar
How do I change this text
I ran R.P in mine right befor the rear pinion gave it up......
Old Apr 18, 2008 | 10:33 AM
Stoichiometric's Avatar
This would be a good one to see Vince or Chuck @ FLT's opinion. I have been using Castrol or whatever else cheap name brand conventional oil.
Old Apr 18, 2008 | 11:01 AM
Bish's Avatar
Vince and Chuck say run only dino at least in their 4L60E's. I had this very discussion with them when they did the 4L60E in my old Tahoe a couple years ago. Not sure their thoughts on the Dexron VI which I believe is a synthetic/dino blend.
Old Apr 18, 2008 | 07:42 PM
I dont know about synthetic fluid for your trans but when I was installin my yank converter it said not to use synthetic fluid.
Old Apr 18, 2008 | 09:14 PM
Hmm I dont remember seeing anything about Synthetic for my PI converter. Ill have to check into that.
Old Apr 18, 2008 | 09:40 PM
Well its looking like I should just use regular Dex III
