Anyone ever rebuild a 6l80e.
I was just wondering if anyone here has rebuilt their 6l80 and if so how difficult was it plus what special tools did you need? I lost 4-6 in mine and was considering just buying the upgraded hard parts and clutches and rebuilding it myself. Any input would be great!
I’ve seen a couple of videos on YouTube. |
Have you built other transmissions before?
I build all the time and don't find a 6l80e difficult at all...but if you've never done one you'll have a hell of a time. You need most of the tools needed for any trans rebuild...but specific tools for the 6l80e are really only the HUGE snap ring pliers (I made my own). You won't get this trans apart or together without them. Also, check out a thread I made over on LS1tech about a vacuum test rig for checking the valve body and pump. you need to make sure the Valve Body and Pump are working properly or you will have a bunch of issues come back. Lastly...make sure you get a proper tune. The 6l80e is a synchronous shift transmission...meaning one clutch is engaging at the same time another clutch is disengaging. Bring one on before the other releases and you'll bind. Bring it on too slowly after the other releases and you'll "flare" This is very very tune dependent trans. |
Originally Posted by MaroonMonsterLS1
(Post 5454896)
If you're up for the task, then go for it. Make sure you can either fabricate your own tool, or fork over the money for the ones you need.
As for PATC...puke Most of their stuff is just rebranded parts thrown in a different box Raybestos makes drop-in module kits for the 6l80e look for those Sonnax has a laundry list of goodies. I would for sure use their pressure regulator valve, line booster kit, and look into their clutch apply kits/pistons Aside from that, replace every piston with a NEW one and every seal with a NEW one. Also pay special attention to the pump (part of the bellhousing) as these can very easily get scored and worn out. A bad pump means a bad transmission. You can do everything else right...and a bad pump will still make the trans shit the bed. I see many of these that need machining to get them back in usable condition. |
Keep us updated
