anyone ever buy from these guys
Old Sep 17, 2013 | 09:11 AM
tashspop's Avatar
then i will move up to the 80 for sure.
Old Sep 17, 2013 | 09:20 AM
tashspop's Avatar
suburbazine, i got a quick off topic question you might have the answer to. my ecu is from a suburban and has a drop down option in the transmission choices which includes the 4l60e and the 4l80e when i use my hptuners. does this mean i don't have to do a segment swap on my ecu to run the 80e trans. just correct harness and option then tuning?
Old Sep 17, 2013 | 12:59 PM
Suburbazine's Avatar
You can either run the 80E on the 60E tune with the correct harness modifications or you can get HPtuners Support to do a segment swap on your tune and use the ISS sensor. I don't know if the HPtuners software is able to segment swap correctly.
I went with Frost's 2 Relay Conversion Kit so I can keep my 60E tune. Plus it was a lot easier than doing harness work myself.
Old Sep 17, 2013 | 01:25 PM
Mangled03gmc's Avatar
Baltimore Whore
Originally Posted by Suburbazine
The BMR people are nuts to offer that warranty on a 60E. Especially at that advertised HP/TQ.
I looked at their parts list and I looked at their warranty...while I think they are legit, I don't see how those parts will make a 60E live for 1 year at 750HP. Heck, I see no mention of input shaft or output shaft upgrades.
I would say they are prob looking at most of those 60's going into a car( much less weight) In a car they will last. Big trucks kill them unless you can get it down under 4k, still it is risky. I am very happy, fortunate to have my Pbuilt lvl2 last for 3+ years behind a boost built 6.0 ( keeping fingers crossed)
Old Sep 17, 2013 | 02:22 PM
Dezert1500's Avatar
I had 500hp going through a stock 125k mile 4L60E with only a shift kit and servo. Over 100+ passes and daily abuse. Not one issue. Truck weight 4,300lbs.
Old Sep 17, 2013 | 06:24 PM
Your other posts said 400rwhp, I dunno about that actually being 500 crank.
Old Sep 17, 2013 | 06:40 PM
Dezert1500's Avatar
20% driveline loss.
Old Sep 17, 2013 | 06:51 PM
03sierraslt's Avatar
What was the engine setup? Tq and max rpm are major players in the life of a 60e.
For what it's worth I did push my built 65e pretty hard and never had a failure. It's now a garage ornament.
Old Sep 22, 2013 | 07:24 AM
tashspop's Avatar
now looking into converters, my current converter stalls at 2300rpm idk what it is since PO built the truck. im guessing i can stick with a stall around there and up for my cam. its a comp xer273. i'm assuming my best rout is to go with circle d but im wondering how this converter might do. would a circle d converter perform $200 better?
link
4L60 4L60E 4L65 4L65E 300mm 2500 High Stall Torque Converter | eBay
Old Sep 23, 2013 | 08:57 PM
I don't like the look of those welds in their picture lol. Circle-D is top notch work and I'd say the $200 is cheap insurance against a balloon or kaboom.
