Anyone correct Chevy lean by using slightly different thickness leak blocks?
Old Mar 15, 2016 | 11:45 AM
lxcoupe's Avatar
Default Anyone correct Chevy lean by using slightly different thickness leak blocks?
My truck sits 3/4" higher on the passenger side. Just wondering if I could install a 3/4" leaf block on the drivers side to equalize things?
Old Mar 15, 2016 | 12:49 PM
madmann26's Avatar
For me, I used a spacer on top of the coil spring to drop it down 1in.
Old Mar 15, 2016 | 12:52 PM
terravast4's Avatar
I have lowering shackles in the rear and my drivers side is one notch different than the passenger side.. it sits perfectly even now
Old Mar 15, 2016 | 12:55 PM
terravast4's Avatar
Old Mar 15, 2016 | 01:03 PM
lxcoupe's Avatar
terravast4, that is interesting so you installed your shackles in different holes?
Old Mar 15, 2016 | 06:12 PM
madmann26's Avatar
This is quite common.
Old Mar 15, 2016 | 06:24 PM
lxcoupe's Avatar
So along those same lines, I could install two different leaf blocks in the rear to achieve an even stance? For instance: 1 inch for the driver's, 1/2" for the passenger?
Old Mar 15, 2016 | 11:56 PM
1bad2k's Avatar
Yes. GM actually used to sell a lift block. They put one on my 06 SSS to fix the lean. It worked.
Old Mar 16, 2016 | 01:05 AM
lxcoupe's Avatar
Great info thanks!
Old Mar 16, 2016 | 07:55 AM
slo04's Avatar
getting a new leaf pack for the drivers side is one way to fix it as well. to alleviate the front lean a spacer on the coil is an option if you have coils up front. the drivers rear spring sags over time seeing as the majority of the weight in the vehicle is on the drivers side as is the fuel tank. it blows especially when you lower them it exacerbates it more.
