Another 4l60E Question; Need 4th gear help
Old May 2, 2016 | 10:02 PM
Wolftrk99's Avatar
Wonder if something isnt applied when not supposed to be.... Dont have flow diagram in front of me at moment.... did you test shift solenoids??
Old May 2, 2016 | 11:35 PM
wyo307's Avatar
Do you have engine braking in first second and third with the gear selector in od? The forward sprag overruns in fourth gear if the overrunning clutch in the input drum is on in fourth it would cause this issue. Cross leak in input drum or valve body.
Old May 3, 2016 | 08:16 AM
stuntstere's Avatar
Registered User
Yeah tested them. Replaced the pressure solenoids and the tcc solenoid due to being out of spec.
Old May 3, 2016 | 08:20 AM
stuntstere's Avatar
Registered User
Forgot to check for engine braking in drive range. Was focused on other things. I think I'll definitely find my issue in the input drum. Just curious as to what else to look for. Just brain storming really before I tear into it again.
Old May 3, 2016 | 10:37 AM
Wolftrk99's Avatar
Check valve body and make sure it isnt warped and torqued properly
Furdkiller
Mar 2, 2025 01:43 PM
tgui
Jul 24, 2016 04:30 PM
slonlow2000
May 26, 2016 07:35 PM
yellow2000S/R
May 15, 2016 11:06 PM
Mtm2015
Apr 30, 2016 12:50 PM
