aluminum control arms and aluminum spindle from 2014-2018 1500
has anyone tried putting aluminum spindles, upper and lower control arms from a 2014 Silverado/Sierra on their 2007-2013? some places specify that their control arms will fit 2007-2018 Silverado/Sierra. would be cool if there was an easy way to drop some weight from the front end.
I've seen that video. It's an awesome truck. Ugly truck is 2 wheel drive. It's also like a 2001ish. Mine is a 2013. I don't think the nnbs stuff will work with nbs and vice versa. I'll watch the episode again. He also has the 4 wheel drive truck that I think he put the aluminum spindles on. I just haven't seen anything that has all aluminum control arms and spindles. I might have to just settle in mostly aluminum stuff.
I have a 2002 Silverado extended cab and a 2013 quad cab. the 2013 would be the logical one to build because it already has a 14 bolt rear end, 6L80 and 6.2 engine. the drawback is that it weighs 500 lbs more than the 2002. it probably only weighs 400 lbs more because I just replaced the tires with some normal weight tires that aren't 10 ply. it's a nicer truck all around.
Thanks for your help.
He is giving away the original 2wd Ugly truck on his channel through merchandise sales.
The version 2 ugly truck, I
believe that chassis is finished and he has the cab and sheet metal on it. I think the motor is finally pretty close to being wrapped up.
There is a thread in this section that talks about the arm and knuckle swap. K2xx aluminum arms and Knuckle on GMT 900 truck. A few guys said they done it. But no one posted pictures of it...
they said the aluminum arm has a larger baljoint that has to be used with that knuckle. The steel arm is smaller and won't work.
All the keyboard worries have to move to places like Fake Book where they can be the post hero and impress people with **** they dont have on projects they dont own.
https://www.performancetrucks.net/fo...3/#post5352849
This thread has a post showing the arms and couple guys say they did the swap.
I was wrong, it was in the K2xx section not the drivetrain section. But other than that no one has posted Photos that I am aware of of the actual swap. Just the few people that say they have done it and it works.
It just happens I have been here for so long and for some reason remember stuff like this.
