Ahh... yet another 4L60E rebuild
Old 08-06-2007, 12:55 PM
  #21
formerly 1BADC10 (12/14/2011)
95ImpSS's Avatar
Originally Posted by Tootall
from what I've read. . . (I'm no builder) If you let the clutches soak, they chance the over all thickness/tolerance. I've read that it's better to set the clearances, then take the clutches back out and let them soak.
Wouldn't you end up with a tighter clearance? Is that considered the preferred method amongst trans builders? I was told to soak before, and you'll see closer to your actual "recommended" clearance level in normal operation. Maybe that's incorrect.
Old 08-06-2007, 03:02 PM
  #22
Tootall's Avatar
yes . . . that was idea behind it. It was another thread just like yours. It was another 4L60e rebuild (basement rebuild was the title). There were a couple of builders that chimed in about it.
here's the thread that I was talking about
https://ls1tech.com/forums/showthread.php?t=631230
Old 08-06-2007, 03:05 PM
  #23
Tootall's Avatar
https://ls1tech.com/forums/showpost....6&postcount=82
Old 08-06-2007, 06:19 PM
  #24
FLT
FormerVendor
FLT's Avatar
The funny part about that thread is that members trans is still messed up.
Old 08-06-2007, 08:17 PM
  #25
Tootall's Avatar
could it have been from all of the gel that he used?
Old 08-06-2007, 10:10 PM
  #26
FLT
FormerVendor
FLT's Avatar
That kid was pretty lost from the get go. My first clue was this....
Old 08-06-2007, 10:11 PM
  #27
FLT
FormerVendor
FLT's Avatar
daretorebuild subliminal message.
Old 08-06-2007, 10:31 PM
  #28
Tootall's Avatar
I just noticed how his case is cracked at the bell, to the right of where his ratchet strap is at.
Old 08-07-2007, 05:51 AM
  #29
95ImpSS's Avatar
Cracked? That's straight up broken. Won't be following that. I'd prefer to follow to recommended specs having clearances set to accommodate normal operation with components engulfed in fluid. OEM specs call for .060" - .085" of clearance. Performance parts manufacturers call for slightly tighter clearance after soaking the clutches for at least 20 - 30 minutes. We know what too much clearance leaves room for. But, I don't wish to know what "no" clearance results to. That's the general consensus from a few builders I know (of which post on this forum). Thanks for posting the link to that thread. I remember reading it before. I'll go through it again tonight to see what I should "not" do this time around.
Old 08-07-2007, 06:23 AM
  #30
FLT
FormerVendor
FLT's Avatar
The gentleman in the picture coded that picture "daretorebuild". Left click on it in his thread and try to save it in your computer. That is what the picture name comes up as. Thought it was pretty funny! I guess I have a sick sense of humor. I have talked to him a couple of times through his build and seems like a good guy. He really did put a lot of work into the thread. But this just shows that this **** is not as easy as it looks. I personally would build, document, install, drive for more than once around the block, and then start working on the thread, so not to look like an idiot. There were quite a few members that blasted this poor guy during the thread. I give him credit for trying.
Quick Reply: Ahh... yet another 4L60E rebuild
