Ahh... yet another 4L60E rebuild
You probably don't want to here this......... It looks to me that you did not have the drum all the way down. The reason I say this is because because that clutch is badly bent where it splines to the 3-4 clutch hub/front planet ring gear. IMO it got hung up the clutch hub when you bolted the pump down. Thus the early 3-4 clutch failure. I've seen this before. Vince
formerly 1BADC10 (12/14/2011)
Originally Posted by Vince @ FLT
You probably don't want to here this......... It looks to me that you did not have the drum all the way down. The reason I say this is because because that clutch is badly bent where it splines to the 3-4 clutch hub/front planet ring gear. IMO it got hung up the clutch hub when you bolted the pump down. Thus the early 3-4 clutch failure. I've done this before. Vince
The clearance was still WAY off too. I always worried about not getting the clutches aligned to fall in completely. Especially since I have no bench to work with this booger standing up. I'll be sure to get it fully installed this time.
Another lesson learned.
Oh, Vince... I fixed your post for ya...
Went to the mailbox late this evening, and found something that made me laugh...
They'll be soaking for quite some time. Got to order one more mod.
BS I've seen it, never have done it personally. I build them standing up and always check the end play with the rear pump half before installing the pump. Then again I learned under the wings of a few excellent builders and from their mistakes, I've know the do's and dont's. You need to get an old case to build of off. Use it as a stand. Or just simply cut a hole in your Black work bench with a hole saw. Now you will have a stand where ever you go.
Tech tip of the day.
Vince... did just what you mentioned. Had to rearrange things in my storage area, but it's up.
Now... wonder what I can do with the salvageable parts lying around.
Oil Pump Assembly (non-truck type)
Reverse Input Clutch Drum and Housing Assembly
Input Shaft and Housing Assembly (non-truck type)
Input Sun Gear
Input Carrier Assembly
Input Internal Gear
Reaction Carrier Shaft
Reaction Sun Shell & Gear
Lo & Reverse Roller Race
Lo & Reverse Retainer, Clutch, and Support Assembly
Reaction Carrier Assembly
Internal Reaction Gear Support
I won't say that this stuff is non-breakable, but may be useful to someone that builds transmissions.
Even have a spare valve body.
Input Sun Gear
Input Internal Gear
Originally Posted by 1BADC10
New clearance checked at .027" with all frictions + 8 of 9 steels. Add the thick steel on the bottom and backing plate on top, things came in b/t the .020" & .040" threshold.
Input Sun Gear
Input Internal Gear
Input Sun Gear
Input Internal Gear
Sounds like you are learning and having fun. What ever you do keep it a hobby, the business will take that away.
Vince
Originally Posted by Tootall
are you soaking your clutches? I've read before that it's not a good idea. . . .
Hey, Vince... parts in stock? I-YIEEE-YIEEE. Here ya go with that poll stuff again.
Doomed now.
Vince
Why would ya say that? Was told otherwise. Hmm... different story. They're in now. No longer soaking.
Doomed now.
Vince
Doomed now.
Vince
from what I've read. . . (I'm no builder) If you let the clutches soak, they chance the over all thickness/tolerance. I've read that it's better to set the clearances, then take the clutches back out and let them soak.
