The age old "steering clunk"
Old Mar 16, 2009 | 03:13 PM
  #21
TX Tahoe Z71's Avatar
Originally Posted by fastlt1
Which end do you take loose top or bottom? Thanks.
There's a bolt right in the middle of the steering shaft under the hood, it's underneath the brake booster and hard to miss. Unbolt it, and pump the shaft in and out 10-15 times.
I've done this twice in the last 1.5 years when the clank comes back, it's saved me from having to buy the redesigned one so far...
Old Mar 16, 2009 | 06:50 PM
  #22
therock's Avatar
I took my 2005 in 6k out of warranty and they put the new one in free. This was a couple weeks ago.
Old Mar 16, 2009 | 07:38 PM
  #23
fastlt1's Avatar
12 Second Club
One Chevy dealer today told me they could not do warranty work on GMC.
Old Mar 17, 2009 | 08:27 PM
  #24
sixltrbtr's Avatar
The bottom but only because it's easier to get to. If it doesn't work i've used the grease kits before. I'm sure you can use bearing grease and just work it in there. Maybe you can find something to make a plug to help get the grease in better.
Old Mar 17, 2009 | 09:27 PM
  #25
rubrhammer's Avatar
Here is a link to a write up on how I do it with Photos and what you need to buy to grease the shaft. With P/N. I also use wheel bearing grease. I find it lasts 8-12 months depending on how much you drive. Everyone who I have done this for has been happy with the results.
Bob
http://jimscampingforums.com/forums/...p?topic=925.15
Old Mar 18, 2009 | 02:08 AM
  #26
AKlowriderZ71's Avatar
11 Second Hall Moniter
We lube the intermediate shaft, but use marine-tec grease. Zero comebacks in 3 years.
Old Mar 18, 2009 | 07:22 AM
  #27
fastlt1's Avatar
12 Second Club
Bob
So where do you actually stick the needle?
Old Mar 18, 2009 | 07:52 PM
  #28
rubrhammer's Avatar
In the photo there is an arrow pointing to the seal. After you push the shaft in so the step on the shaft (step is circled in the photo) goes into the seal you can easily insert the needle between the seal and the shaft.
Bob
Old Mar 18, 2009 | 08:08 PM
  #29
fastlt1's Avatar
12 Second Club
So you are pretty much fill the plastic dust cover up with grease.
Old Mar 20, 2009 | 02:23 PM
  #30
fastlt1's Avatar
12 Second Club
Thanks guys. Greased it up today. Filled the shaft up and greased around the dust cover. Seems to be better. Looks like it would work better if one end was sealed up and it had a grease fitting. Might try that next time.
simman22
Jan 21, 2017 10:27 PM
dsbodley
Nov 14, 2015 09:46 PM
Blklgt
Sep 28, 2015 03:21 PM
vipergtrdj
Sep 16, 2015 07:06 PM
George C....
Sep 11, 2015 04:45 PM
