Accumulator Pistons
Old Jun 15, 2008 | 10:18 AM
Champion201's Avatar
Default Accumulator Pistons
I'm not sure if I spelled the name right but hopefully yall understand what I mean.
Anyhow, how difficult is it to swap out the plastic ones with some billet ones? Is this something a shade tree mechanic attempt to do, like the servos, or is it more indepth than that?
If I do take it to a shop about how many hours would they charge?
Thanks
Old Jun 15, 2008 | 03:08 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
The one you'll have to worry about is the 1-2 accumulator piston. If you drop the trans pan, you'll see a sort-of round housing that looks like what's illustrated on the upper right side of the pic below (just to the right of the two solenoids - A & B):
*edit*
FYI... the 3-4 piston is a metal piston. I wouldn't worry about this one boring under wear & tear.
Old Jun 15, 2008 | 08:12 PM
Default Thanks
Thanks, the pics sure help out! So the stock 3/4 is already made of metal huh?
Old Jun 16, 2008 | 07:03 AM
95ImpSS's Avatar
Took a load of pics over the MANY times I've rebuilt transmissions. Search the Drivetrain section, and you'll see loads of threads by a LOT of users who've broken these open.
Yes, that one's a metal one. Unless you know of any seal damage (or otherwise), I wouldn't go beyond the 1-2. If you're looking to replace that one, you'll be dropping more than just the pan and 1-2 housing. Search the board for one of a few 4L6xE build-up threads. You'll get an idea of what's involved.
Old Jun 16, 2008 | 08:23 PM
Thanks!
Old Jun 17, 2008 | 07:42 AM
built408's Avatar
If your replacing the 1-2 piston, you might as well change the forward piston too. It is plastic and breaks just as easy as the 1-2.
Old Jun 17, 2008 | 11:15 AM
95ImpSS's Avatar
Since the pan would be down, good point. That can be found under the dark grey, bolted cap (top left of first pic). Have fun!
Wolftrk99
Dec 3, 2015 08:12 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
turbo6c3
Oct 5, 2015 06:11 PM
sTNT971
Sep 26, 2015 04:22 PM
