ABS sensor?
Old Jul 9, 2012 | 03:50 PM
zeake's Avatar
Default ABS sensor?
Ok I have a 2500hd that at really slow speeds when braking one front wheel thinks it is locking up and starts the shudder of the antilock brakes. The steering wheel pulls to the right when it does this.
The abs light comes on frequently and the ding like the door does with hit 6 times sometimes and 4 other times. For about a week I could drive exactly two miles and it would ding 4 times. LOL crazy huh.
The other day the I get in and start down the road and the ac blows hot air. When I say hot I mean 140 degrees. When I got in the truck the thermometer I have sticking out of the ac vent said 110. After shutting the truck off and turning it back on it blows cold again. It has not done that since. posting the ac info in case somehow the bcm or computer is at fault. I doubt it but you know better safe than sorry,
My mechanic did clean the abs sensor as well as the grounds all over the truck. Even the one that the abs unit uses. The killer is the problem got worse once he cleaned the sensors.
It has posted codes but I will have to get them.
got the code c0227
Thanks in advance
Old Jul 9, 2012 | 04:03 PM
zeake's Avatar
Old Jul 9, 2012 | 05:20 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Gm does have a TSB about cleaning the corrosion on the hub were the sensor sits. Have you lifted that side up off the ground and checked for play in the hub??? If the hubs bad it will also cause erratic readings.
Old Jul 10, 2012 | 04:44 PM
zeake's Avatar
We did the tsb and it got really bad. My technician came to the conclusion that it was mechanical and checked to see if the hubs had the same tone rings in them. Guess what. Different. Swapped one so they both matched and it is fine now. The new hub did have a new abs sensor though.
Old Jul 10, 2012 | 04:54 PM
1FastBrick's Avatar
Glad you got it fixed
Old Jul 10, 2012 | 05:09 PM
zeake's Avatar
Thanks. I would have went wrong for sure.
Pimpinpete
43
Dec 22, 2017 08:13 AM
RustyD
May 23, 2016 07:04 PM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
Blklgt
Sep 28, 2015 03:21 PM
