ABS Engaging on moderate braking
Old Mar 19, 2009 | 11:41 PM
fredkj3's Avatar
Default ABS Engaging on moderate braking
my abs is kicking in when i apply mr brakes moderately to forcefully... if i ease on the real easy it doesnt kick in but if i get down on them even the slightest bit my ABS kicks in and wont let me push the pedal down any further... what would cause this??? my tires are all the same size and it doesnt have any lights on dash.. no ABS light on... so does it think that one tires spinning faster than another?? and what can i try to do....
Old Mar 20, 2009 | 12:50 PM
budhayes3's Avatar
PT's Slowest Truck
Probably have some rust or debris on one of the front ABS sensors, there's a recall for that exact condition. A google search will probably yield the recall info
Here's a quick link I found with some info about it, but not the cleaning procedure...gotta get back to work or I'd dig a little deeper for ya..
http://www.consumeraffairs.com/news0...al_recall.html
Actually, from reading that link, the sensor gets pushed away from the reluctor wheel on the hub due to corrosion
Old Mar 20, 2009 | 01:21 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
You could also check for play in a worn out wheel bearing/hub assembly.
RustyD
May 23, 2016 07:04 PM
turbo6c3
Oct 5, 2015 06:11 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
Blklgt
Sep 28, 2015 03:21 PM
01silvy
Sep 26, 2015 10:20 PM
