'95 nv3500 on a 2002 LQ4, slave and clutch need help
Old Feb 8, 2016 | 06:58 PM
Alco's Avatar
Default '95 nv3500 on a 2002 LQ4, slave and clutch need help
I might be over thinking this ( probably ) but I want to run a slave of a 2002 silverado instead of the fork that came with the 1995 transmission .
I have clearence issue and want to cut the case to remove the portion where the clutch fork and slave sit's
Can I just delete the clutch fork and slave and buy a clutch flywheel from a 02 silverado bolt it to the Lq4 and buy a 2002 slave and install it in the case without any major mods ?
2002 slave
1995 slave
Old Feb 12, 2016 | 08:55 PM
Alco's Avatar
no body ?
Old Feb 12, 2016 | 09:00 PM
CCrowell2's Avatar
Yes I think so, my slave in my 97 looked like the 2002 slave.
Old Feb 14, 2016 | 06:23 AM
Alco's Avatar
ok from what I found the input shaft bearing retainer as to be replace with a newer model if it's only that well it's gonna be an easy conversion !
Old Jun 27, 2016 | 08:07 PM
_zebra's Avatar
makes children cry
i know it's 4 months later, but...
check your master cylinder line connection first. my 99 has a roll pin connection up top & the quick-connect on the slave. i believe 01 or 02 was when they switched it to the quick-connect up top with the line roll pinned into the slave
Tbss6
Jan 31, 2016 08:11 AM
carbed94z
Jan 21, 2016 05:18 PM
Aboss
Jan 17, 2016 11:15 AM
rms-man
Jan 12, 2016 05:18 PM
