9.5 inch 14 bolt bearing
Old Jan 15, 2012 | 07:04 PM
BadAssChevy327's Avatar
Default 9.5 inch 14 bolt bearing
so i finally ordered my detroit and its on the way tomorrow! I'm going to do 4.56s and some other stuff in a couple months but for now we are just throwing in the diff so i have it for track coming up.
what carrier bearings do i need? i can't find it and i find some but then not sure if correct ones. and whats with these rear ends having adjusters on one side and shims on the other?
Old Jan 15, 2012 | 07:28 PM
someone help!!! lol.
Old Jan 16, 2012 | 08:35 AM
sureshot's Avatar
GM 9.5 CARRIER BEARINGS & RACES KIT BEARING RACE TIMKEN
Old Jan 16, 2012 | 01:56 PM
Thanks bro.
Old Jan 16, 2012 | 08:29 PM
sureshot's Avatar
Originally Posted by BadAssChevy327
Thanks bro.
No problem! And yeah, the 14 bolts do have an adjuster on one side, with shims on the other.
Old Jan 16, 2012 | 08:34 PM
Bill Reid's Avatar
Yup, can't beat Ron's. Gotta a 14 bolt stuffed with everything from Ron's sitting on the floor of my garage waiting for me to get a driveshaft built!
Old Jan 19, 2012 | 07:45 PM
1FastBrick's Avatar
Custm2500's Rude Friend
That sure is pretty Bill!!!
Just a side Note on the 14 bolt 9.5
I believe the differential carrier bearings are the same through out the years but the outer axle bearings and axles seals are different deppending on your application. The pinion seal also changed. so make sure you get the correct kit for your application.
Also you can get new C-clips through the dealer for around 3-4 dollars each.
HTH
5.3Okasai
Mar 9, 2022 01:07 PM
vipergtrdj
Aug 6, 2015 10:19 PM
Jake75
Aug 5, 2015 01:26 PM
