9.5" 14bolt limits? Discuss
Old Dec 27, 2010 | 07:03 PM
Atomic's Avatar
I have a gauge for that
Yep, the smallest diameter is where the c clip holds them in, and even that is about .8" I think.
Old Dec 27, 2010 | 08:11 PM
TURBHOE's Avatar
And that takes no real twist just maybe side pulling load under extreme cornering
Welll I think unless I go 8 lug. It's my only good choice. I may build it a bit though. With axles,trutrac and a girdle.
Old Dec 27, 2010 | 08:52 PM
Atomic's Avatar
I guess ill be one of the guys to really push it. 800hp, 35" tires, 6400lbs, eaton lsd, huge thick cover, 4.56 gears...
Is it DrX or supersub that also has a lot of power through one of these?
Old Dec 28, 2010 | 04:24 AM
TURBHOE's Avatar
Supersub is pushing over 700 (iirc) through one
Old Dec 28, 2010 | 01:33 PM
TURBHOE's Avatar
can we put 2500 8 lug hubs on our 2500 spindles?
Old Dec 29, 2010 | 01:11 AM
BadAssChevy327's Avatar
I hear people running 9s in trailblazer ss's with the 9.5 14 bolt.
Old Dec 29, 2010 | 03:41 PM
TURBHOE's Avatar
i think the problem is that with a diesel that make 600hp is that it will make 1200lbft of torque by 1600rpm. so that's my fear, being that i broke the 8.5 so many times i don't wanna spend $1200 on an axle for it to not hold the power and rip the axles in half. lol. i think the advantage of a FF is that the axle its self doesn't "see" the weight of the truck and the torque of the motor. where as a SF see's both so if the weight load is enough to combined with the twist it can put it in a bad spot and cause breakage. i think that's what happen to the 8.5. my tahoe transfers weight like crazy and it twist to the left, which is the axle that always broke. i think it put it in a bend bind as well as a twist and it didn't like it.
if i knew for a fact the 9.5 would hold i'd be all over it for sure.
Old Dec 29, 2010 | 03:53 PM
DrX's Avatar
DrX
So far, so good with mine, but I have only been using it to spin the tires. We'll see how it holds up when I put the slicks on it.
What are the rules re these c-clip axles at the track?
Old Dec 29, 2010 | 04:13 PM
TURBHOE's Avatar
there only good for so fast then you have to go ff, 9" style outers or c-clip eliminators. and every body says stay away from eliminators for street use.
Old Dec 29, 2010 | 04:15 PM
1Bear's Avatar
I can’t speak as to the current rules, but as of 2009 any vehicle that ran 10.99 or quicker had to have c-clip eliminators if the rear end was a salisbury type that originally used c-clips.
