88-98 9.5" swap into 99+ thread
Old Dec 19, 2006 | 09:11 PM
parish8's Avatar
single digit dreamer
it would be sweet if it came with a posi. i would just try it or try it with a rebuild. might be a real cheap set up.
Old Dec 19, 2006 | 09:24 PM
cangrick's Avatar
I don’t know if this helps but I put a 14 bolt in my 94 w/ aluminum drive shaft and old 10 bolt and I had to get u- joint part# 2-3050. I got mine from advance auto parts.
Old Dec 19, 2006 | 09:29 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
If I read correctly these brackets would allow you to run some discs on the early model 14bolts.
http://www.ruffstuffspecialties.com/...cket-p-10.html
Old Dec 19, 2006 | 09:38 PM
Dock Rocker's Avatar
check www.car-parts.com. That will help you find a rearend cheap. I will ask about the yoke and get back with you tomorrow. I have an eaton in my 1991 and its ok for your truck I might go with a spool or the tru track. If you need any measurements I will be happy to climb under and put a tape on it.
Old Dec 20, 2006 | 01:41 AM
James B.'s Avatar
Not sure why you're calling it a 12-bolt with a 14-bolt cover. On the phone with these people call it a "9.5 14-bolt" to avoid confusion. The 9.5" has 14 cover bolts and is semi-floating, came either open or with a G80, 5-lug, 6-lug, and 8.
BTW Dave, 8-speeds has been done before
Old Dec 20, 2006 | 05:50 AM
Quik's Avatar
5 year bitches!
Originally Posted by Bowtie70SS
I thought the 14 bolts had locking diffs in them? Sounds like an easy swap...a set of universal perches for $20 and worse case scenario an adapter U-joint for $50 tops plus a little welding. The real deal would be to find a Dana rear end out of a 454SS truck. Yeah that's right they had a Dana in them and they are bulletproof and have a 5 on 5 bolt pattern though along with 3.73 gears. Hell you're in Nebraska what about a 2 speed rearend out of a grain truck? With everyone wanting 6L80's you'd be the first with a 8 speed setup.
Dave
buddy has a older 454ss and his is a 14bolt
Old Dec 20, 2006 | 06:22 AM
parish8's Avatar
i thought the "12bolt" or "14bolt" was the number of bolts in the ring, not true?
Old Dec 20, 2006 | 06:57 AM
1slow01Z71's Avatar
Bolts on the rear diff cover.
Old Dec 20, 2006 | 07:16 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Couple of things that may help--
* TA makes a girdle cover for the 14 bolt housings -- cheap and fast delivery from them direct
* The axles that are available (at least for the housing I used) were "stock replacement" customs -- 33 spline, hard alloy, whatever lug pattern you want
* Get one with brakes if you can, then at least you know there are brakes made that fit your setup, even if they are stockers. Otherwise, contact me for a race shop that will custom fab rotors for you
* To make it easy on yourself, see if you can find a modern 14 bolt 9.5" s.f. (they came in a lot of things, including the 1500 crew cab, all the HDs, etc.) -- but I couldn't find one locally and just got the run around from the custom search site. I ended up buying an empty housing from GM for $900 and adding the detroit locker, axles, r&p from aftermarket (see the above about brakes lol)
* Give Joe Vinci a call about mycroniting the R&P
* Don't listen to anyone who says "oh yeah that will bolt right up" or "yeah those stock parts should fit" -- none of them do and none of them will Just buy all the fasteners up front and save yourself 900 trips.
Old Dec 20, 2006 | 09:23 AM
67SS509's Avatar
10 Second Truck Club
I installed the 05-06 SS style 14bolt/9.5" rearend in mine. 100% bolt in, bleed the brakes and drive. Brakes are as good as disc's and no side effects. I used the eaton posi and a 1350 yoke. Neat thing is this rearend only weighs 32 lbs. total more than the 10 bolt. I could not find aftermarket 33 spline axles/6 lug so I used the GM 33 spline/6 lug.
As far as wheels I'm running 30"tallx13.50x15 M/T streets on 15x10 steel wheels with 6-3/4' backspace. They tuck under the fender wells great.
When my server gets back up that hosts my pics and videos I'll post some.
