80E upgrades?
Old Oct 8, 2015 | 10:13 PM
Pro52R's Avatar
Default 80E upgrades?
So I finally bought a 80E. It's from a 2003 2500hd 2wd.
Fluid is darkish red. Doesn't smell burnt. It's going in a 01 Yukon with a 5.3/cam and boost. Thinking a 3200-3600 stall? Rev Max? FTI? (budget friendly)
What's the bare minimum I should do? Besides a shift kit. I just want to get this back on the road. Billet input shaft? Plan on running about 13-16psi.
Old Oct 9, 2015 | 12:24 AM
1bad2k's Avatar
How much power does it make? Def a shift kit like you mentioned or even dual feed mod it. Probably won't need a billet input shaft if you won't be locking tc at wot. I have heard about some billet input shafts snapping anyways, but read the Jakes billet shaft is the strongest. I didn't do one because I was in a hurry to get the truck back on the road.
Old Oct 9, 2015 | 07:47 AM
Fast355's Avatar
I tuned one (Duramax/85E) that is holding about 800 ft/lbs and heavy towing. Stock trans with a Transgo, Deep pan, Good tune and Good cooling.
Old Oct 9, 2015 | 12:07 PM
Atomic's Avatar
I have a gauge for that
Stock input shaft lasted a couple years at 1000hp, wasn't until I went to 4 slicks that it broke on the 4th or 5th run on the 2-3 shift.
Generally just try to make sure the intermediate clutches are set up nice and tight because they always get beat up in the 80s.
Old Oct 24, 2015 | 03:53 PM
Dylpicle8's Avatar
Shift kit, intermediate sprag. Happy boosting!
Old Oct 24, 2015 | 06:05 PM
tgui's Avatar
Is your Yukon 2wd as well? There are a few mods needed if not.
See my thread if you want to go nuts on a rebuild. Drilled drum, internal dual feed and all new clutches solenoids and such.
Transgo has a good dual feed kit that doesn't require taking the trans apart.
Oh, I'm going turbo with a max of 550-600 ftlbs tq at the wheels. I picked up a circle-d converter for $550. Give em a call. They're nice and patient.... They put up with me after all
slowlsx
Apr 23, 2016 03:49 PM
trxmxzx
Oct 24, 2015 03:52 PM
Silveraydo
Oct 13, 2015 08:49 PM
thundurchasur
Oct 10, 2015 02:26 PM
thundurchasur
Oct 9, 2015 08:26 AM
