80e Pressure Drop During 1-2 Shift = Cooked Clutches
Old Mar 21, 2015 | 05:33 PM
  #41
jakeshoe's Avatar
Originally Posted by L8ERBRO
So, unfortunately for me, your opinion is incorrect unless there is some other pick up issue, the fluid level is indeed correct and it still has the soft 1-2 @ WOT.
My statements weren't based on an opinion. They were based on fact that you have confirmed by your posting.
My shop builds HUNDREDS of 4L80E's a year. I wouldn't rebuild a transmission that had burnt 1-2 clutches and still air checked good for free. I would charge for the repair because it points with great certainty to a low fluid condition. Especially on a unit that dyno'd good and by your own admission made proper pressure in the truck, except on WOT 1-2.
Your fluid level was low during your WOT runs. You glazed the intermediate clutches by doing so. So until they are replaced, you will have a soft WOT 1-2 shift as mentioned previously. The reason you didn't cook them completely out of the transmission is likely because FLT used a good clutch material.
I can't even grasp the concept of why a customer thinks they can run a transmission low on fluid and it should be OK, and if not it should be the builder's fault.
Would you say the same thing if you spun all the bearings in your engine because it was 2 qts low during WOT? I highly doubt it.
The rod bearings in an engine rely not so much on the pressure as the hydrodynamic wedge created by the oil.
A transmission ABSOLUTELY relies on the pressure to create the force required to clamp it. If it's not there, the clutches slip, and once they slip they are ruined.
As I mentioned previously NO builder can build a transmission that will live without proper fluid level. It's doesn't matter how much you pay for it, how well it was built, how popular or reputable the builder is, what the internet consensus is on the builder's abilities, or how many times they repair it due to your mistake.
It seems to me that you owe FLT for one rebuild and need to pay them for another.
Old Mar 21, 2015 | 05:35 PM
  #42
L8ERBRO's Avatar
Originally Posted by GMCtrk
I can't answer that for sure, however, it's probably assumed when you're playing at this level that this stuff is understood. There are quite a few critical steps in installing a transmission including the torque converter clearance, using the correcting trans line fittings, proper fluid level, etc. Any of those can result in a failure, and we have seen several cases of these on this forum over the years.
The pressure drop is still there though - the tech hooked his gauge up and we confirmed it after we dropped the pan earlier. If the trans was cooked already and low fluid was the real issue, over filling by two quarts should have brought the pressure back up and didn't.
Old Mar 21, 2015 | 05:41 PM
  #43
jakeshoe's Avatar
Exactly,
It IS assumed that whoever installs the transmission knows the critical installation steps and they also assume the responsibility that it is done correctly. It is completely beyond the transmission builder's control.
We have seen so many failures due to installation issues (with fluid level being the most common) that I wrote a packet that ships with each transmission addressing every aspect of installation I could think of that causes failure. Since we began sending these out, the failures have been reduced tremendously.
A transmission company shouldn't have to send out a pop-up book to ensure our product is installed correctly but we have pretty much resorted to that.
I also don't feel liable when a product fails that is obviously an installation issue. It's not our responsibility AND we took extra steps to educate the customer/installer of the critical checks.
Old Mar 21, 2015 | 05:44 PM
  #44
jakeshoe's Avatar
There is always a slight drop at the moment of the shift. The clutch apply piston moves and the volume of fluid required causes a pressure drop as the regulator takes a moment to catch up.
The 1-2 shift circuit can be improved greatly on a 4L80E, but that depends on the valve body design. We see intermediates come back with little or no hot spotting after years at 1200-1500 RWHP.
Old Mar 21, 2015 | 05:47 PM
  #45
L8ERBRO's Avatar
So please explain why the pressure drop is still there, I'm curious about that one.
As far as me owing FLT, very funny. First of all, and as mentioned previously, I am a total novice to all this, Chuck is well aware of that and Chuck never told me to over fill past the fill line and by not doing so would glaze the clutches as you believe. Because of that alone, how am I responsible? Not to mention, it says, "DO NOT OVER FILL" right on the dipstick + I never insisted he rebuild the first one for free. I simply told him what happened and he said he would warranty it - simple as that. You making the statement that I owe them for two transmissions is uncalled for.
Old Mar 21, 2015 | 05:56 PM
  #46
jakeshoe's Avatar
As far as me owing FLT, very funny. First of all, and as mentioned previously, I am a total novice to all this, Chuck is well aware of that and Chuck never told me to over fill past the fill line and by not doing so would glaze the clutches as you believe. Because of that alone, how am I responsible? Not to mention, I never insisted he rebuild the first one for free. I simply told him what happened and he said he would warranty it - simple as that. You making the statement that I owe them for two transmissions is uncalled for.
It would likely be fine if it was "FULL" and not over the line. I recommend being over by 1/4" as a margin of safety.
Chuck isn't responsible for your fluid level. You paid him to build a transmission and he did so. Anything he did beyond that was a courtesy. I'm sure he rebuilt it as a courtesy too.
I will bow out and discontinue my tech assistance, as it seems you have it all figured out.
Old Mar 21, 2015 | 05:57 PM
  #47
L8ERBRO's Avatar
Two more questions then:
If there is always a slight drop at the moment of shift, why does my 1-2 WOT shift have a very lengthy 20psi drop and the others do not?
Why is there no drop on the 1-2 under part throttle?
Old Mar 21, 2015 | 06:00 PM
  #48
L8ERBRO's Avatar
it would likely be fine if it was "full" and not over the line.
my fluid was always "full" and not over the line!!!
Old Mar 21, 2015 | 06:10 PM
  #49
L8ERBRO's Avatar
Sounds to me like you're bowing out because you can't answer my questions and by your own admission state that the 1-2 shift can be greatly improved by the valve body design. This sounds to me like a valve body problem just as I suspected, just as 2 GM master techs suspected and a couple of other tuners suspected.
For someone who has built hundreds of transmissions, you SHOULD be able to at least show your intelligence of the 80e and answer my questions. As I have absolutely NOTHING figured out...I'm an admitted novice here.
Old Mar 21, 2015 | 06:26 PM
  #50
jakeshoe's Avatar
I don't need to show my knowledge of the 4L80E. It's been more than proven.
