80e failure list
Originally Posted by Yank
Quote:
Originally Posted by bud8fan
is this dave...hey guys im having an issue right now with my new setup...i ordered my new sc3000 and had it sent to nelson performance...allen does not have it locking up at WOT so im really confused as to why im having this problem right now...i know when i pull this thing im gonna have to send you the verter....what is the turnaround for this thing...what do you think.....
https://www.performancetrucks.net/for...d.php?t=441506[/QUOTE
I would have the converter cleaned but I would bet the clutch matter is from the trans
Mike
i do have a question thou...why would you bet it's not the converter...
I have seen many 4l80-e trans that will not hold up if the converter feed is not reworked the factory shuts off the feed to allow the truck to idle in gear as the converter is tight and large
the stock converter has a large fluid volume and will not heat up as fast as a small high stall will with no oil feed
this feed is shut off till about 2500 rpm so the converter oil gets hot and will boil in the converter this will super heat the clutch packs and cause an issue it is a must to rework the feed to allow full supply of oil to the converter for cooling and correct action of the trans
ok...thanks for the info...wonder if others reworks the converter feed....BTW..i never seen anymore than 185 temp on this tranny either..it usually hanges around 160 degrees
you would not see a temp increase as the time is shoft that this happens and the oil is deluted when it get to the pan the action is the oil from the converter to the lube supply this is a normal state but the high stall make matters worse
you have to rework the supply as to a TH400 to stop converter and clutch issues on the 4l80-e
that is why you see 4l80-e owners complain about clutch chatter and trans failures
How do I change this text
Sonnax has a tcc control kit or fix, maybe he is referring to that, though I have heard little talk about anyone using them. Vince do you ever install the sonnax tcc kit in any of your transmissions?
well i just found out today we had a bearing failure in the converter and yank is fixing it under warranty...said it doesnt happen very often but it does happen...dave ask me what in the hell did i do to his converter...lol
