80e driveshaft??
Old Jun 21, 2011 | 08:44 PM
  #21
swift700's Avatar
I went with 3 1/2" steel. 66 1/8" center to center.
Old Jun 22, 2011 | 12:01 PM
  #22
MPFD's Avatar
11 Second Truck Club
The best place to go around here is Power Drive in Wichita, they have built a couple of my drive shafts and I've never had a problem with any of them. I'm pretty sure I have a 80e Yoke if your interested PM me.
Old Jun 22, 2011 | 12:43 PM
  #23
TXjeepTJ's Avatar
Originally Posted by Jake99
Ok to anyone who wanted to know what I ended up doing.. stock driveshaft then got a stock replacement u joint from Orileys and this slip yoke..
http://cgi.ebay.com/ebaymotors/ws/eB...ht_1526wt_1163
I slid the yoke all the way into the trans and had to pull it out right at an inch to bolt it to the axle. So I figered this should work fine. has maybe 300 miles on now everything seems to be working great.
did you need to buy a conversion u-joint to go from the bigger 4l80e yoke to the smaller 4l60e driveshaft??
Old Jun 22, 2011 | 03:12 PM
  #24
N20GMC's Avatar
That yoke takes the same u-joint thats already on you 4l60 driveshaft. Its the 1 1/8th dia. The other 4l80 yokes take a 1 3/16th dia u-joint. SO when you buy that slip yoke you can get a solid u-joint thats stronger than a conversion one. Atleast thats what I was told by the guy thats doing my driveshaft.
Old Jun 22, 2011 | 09:57 PM
  #25
Jake99's Avatar
Yep thats correct. You just have to buy a factory replacement u joint so you have the inside clips, you cant reuse the stock ones anyways, but it fits just like the stock yoke did.
Old Oct 24, 2011 | 08:20 AM
  #26
Phantom's Avatar
11 Second Club
Can you post another link to the yoke you used? Thanks
Old Oct 24, 2011 | 01:10 PM
  #27
Phantom's Avatar
11 Second Club
is it one of these?
GM Turbo 400, TH 400 / 4L80E Transmission Slip Yoke | eBay
Old Oct 24, 2011 | 03:26 PM
  #28
LsF-150's Avatar
The first one with your factory rear u-joint
Old Oct 24, 2011 | 03:48 PM
  #29
Phantom's Avatar
11 Second Club
thank you very much
Old Oct 24, 2011 | 06:58 PM
  #30
Jake99's Avatar
The first one looks right, I couldn't find it anywere but I think thats it.
turbo6c3
Oct 5, 2015 06:11 PM
Wrecker 426
Sep 30, 2015 09:39 PM
jscherbs
Sep 30, 2015 07:54 AM
mitchellmade
Sep 27, 2015 08:27 PM
ice17
Sep 22, 2015 05:18 PM
