80E crossmember
Old May 17, 2007 | 07:41 PM
wkdivr's Avatar
Default 80E crossmember
Anybody have any specs on the difference between the 60E, and 80E crossmembers. I can get ahold of a stock crossmember, and would like to modify it to fit an 80E "just in case"
Old May 17, 2007 | 08:18 PM
adam1803's Avatar
all you have to do is cut off the mount, flip it around so it faces the rear of the truck, and slot the bolt hole and your all set.
Old May 17, 2007 | 08:53 PM
Quik's Avatar
5 year bitches!
a 00 crossmember is different then a newer one. you cant just cut our crossmembers and flip.
Old May 18, 2007 | 12:36 AM
Blown06's Avatar
8 Second Truck Club
I used a crossmember for a 3/4 ton truck, drilled the frame rails right behind the stock crossmember mounts, cut the box off of it, shortened it by about an inch and moved it forward, bolted it in, looks good to me.
Old May 18, 2007 | 10:36 AM
Quik's Avatar
5 year bitches!
you guys must not get the point. he has access to a spare 60e crossmember and wants to know what is all involved or specs of how to mod this 60 crossmember to fit an 80
Old May 18, 2007 | 10:39 AM
adam1803's Avatar
Sorry, didn't realize that the newer ones were different.
Old May 18, 2007 | 10:41 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
As long as you aren't changing between 2wd and 4wd, it's just a matter of welding a plate and some gussets. I don't know the dimensions exactly, but Parish may still remember them for 4WD (as I recall he was the first to do this). I think he welded a 3 inch plate on and gusseted it.
Old May 18, 2007 | 10:47 AM
04BlackSilverado's Avatar
Its actually six and a half inches back for the 2WD trucks.....
Old May 21, 2007 | 03:47 PM
BirchSSclone's Avatar
I'll try to remember to post pics of mine. I just finished mine this weekend. I cut the entire center hump section, moved it back about 6 1/2 inches as stated above and got some 4" X 10" X 1/4" plate and welded everything back together. Everything is plently strong and I still have access to drop the tranny pan if I ever need too. Kind of hard to explain without pictures. I'll try to remember about the pics. tonight.
Old May 22, 2007 | 11:46 PM
Sorry for the delay. I snapped a few pics tonight. Not the best pictures but you can kind of get the idea. Let me know if you want more details. Comparred to the $300 cost for a new one, I think I did pretty good being that I'm only in mine for $10 (the cost of the 4" X 10" X 1/4" plates).
