80 + mph fan or something turning on?
Old Jan 25, 2007 | 03:34 PM
Kerr's Avatar
Default 80 + mph fan or something turning on?
I used my pops 04 2500 gmc to deliver a car yesterday. We covered about 700 miles with a load. Everything went grate and the truck pulled like crazy for a gas (6.0 ) truck.
At any rate. The trans or something at 81 mph + sounds like a auxiliary fan or something turns on. It does it in over drive and in drive. The Truck has 4:10 gears and stock size tire so in Drive it was about 4-4200 rpms and over drive was 3-3200 ( sorta hard to see the teach just right)
Anyway all the coolant gauges read cool, cooler than i thought to be honest. The motor never got over 200* says the gauge and the trans temp gauge only mover to the second little mark above 100, Which it had did that in the first 2 miles.
So anyway anyone got an idea of what i was hearing turn on and off.
Old Jan 25, 2007 | 03:45 PM
TXsilverado's Avatar
you were hearing/feeling the A/C compressor
Old Jan 25, 2007 | 03:49 PM
Kerr's Avatar
ah, So what does it just do it at those speeds?
Old Jan 25, 2007 | 04:01 PM
no it does it at idle too. basically any time the ac is turned on
Old Jan 25, 2007 | 05:55 PM
MonteCarlo31's Avatar
Got a 04 Quadra steer 3/4 ton yukon with the 6.0 and 4.10s, it's the cooling fan, it'll roar b/c the heat that it is feeling is causing it to spin along with the airspeed difference/flow thru the radiator.
Old Jan 26, 2007 | 08:42 AM
Kerr's Avatar
Ah oh... that makes more sense... cause we didnt have any air on.. it was only 30* out side
Old Jan 26, 2007 | 10:27 AM
bigkountry's Avatar
Compressor will also kick on if you are running the defroster.
flatblack83
Jan 3, 2026 07:10 PM
Y2KLimited
Dec 5, 2015 09:57 AM
03regcab sierra
20
Aug 3, 2015 12:11 AM
bsgiffor
Jul 19, 2015 11:14 AM
mr03silverado
Jul 17, 2015 02:15 PM
