6L80 2nd to 3rd intermitten "neutral"
Old Apr 12, 2015 | 03:24 PM
slovarado's Avatar
Registered User
Default 6L80 2nd to 3rd intermitten "neutral"
Truck is a 2014 Silverado, 5.3, 6l80 , 4x4. 12500 miles
So my problem is, randomly, usually after i drive it for a while then make a quick stop ( shut the truck off for a few minutes) The transmission neutrals between the 2nd and 3rd gear shift at about 30 percent throttle. The engine usually revs about 1000 to 1500 rpm, then catches 3rd.
I took it to the dealership and they "can't duplicate the complaint" and says all is normal.
Any Ideas?
Old Apr 13, 2015 | 05:21 AM
SlowDude's Avatar
Gear selector switch on side of transmission has a slight adjustment.. Have you messed with this any?
Old Apr 13, 2015 | 01:22 PM
slovarado's Avatar
Registered User
Not at all, you think it clould be the culprit?
Old Apr 13, 2015 | 08:32 PM
SlowDude's Avatar
Most likely not if you or anybody else has not messed with it. They just dont go out of adjustment by themselves but I would put my hands on it to make sure its not loose for some reason. If it has moved any would will see the wear in marks next to the bolts.
Texas5.3_1251
Mar 5, 2016 08:10 PM
Chevy305
Sep 28, 2015 09:21 PM
97_ek
Sep 23, 2015 09:16 PM
jtphelps289
Sep 11, 2015 06:37 PM
