Is the 65 the same as the 60
Old Aug 1, 2006 | 11:07 AM
Mangled03gmc's Avatar
Baltimore Whore
Default Is the 65 the same as the 60
The 65e tranny is the same as a 60e other then some beefed up parts correct. I tried a search so don't grill me too bad. What kind i power can i put threw this thing and keep it togather. It will have a shift kit stall and servo.. Also I shouldn;t need any special tune for the 65, it is plug and go correct. Thanks for the help John
Old Aug 1, 2006 | 11:08 AM
TXsilverado's Avatar
5th planetaries is all i know of extra in the 65e.
Old Aug 1, 2006 | 03:55 PM
Zick's Avatar
I believe it also has a hardened input or output shaft too.
Old Aug 1, 2006 | 09:19 PM
Baltimore Whore
So basically what you are saying is this won't be able to take that much more abuse being beefed up then a 60e beffed up? anybody
Old Aug 1, 2006 | 09:31 PM
04Denali's Avatar
A stock 65 is 20% stronger than a stock 60
If you go to the dealership and have them change the parts over to a 65 it has about 800.00 dollars worth of stronger parts. and yes it would be a plug and play
Mark
