6.0 swap help...
Swapping in a 04 lq4 on a 06 silverado. Truck has 4l60 with a yank convertor. My question is i need to use the 6.0 spacer with the 5.3 flywheel to match everything up correct?
Maybe i should've been more specific lol.. Need flywheel information. Motor is 799 headed with custom grind cam,tbss intake and 90mm throttle body. I need to know what flywheel to use and if i need to run the spacer that was with the 6.0 flywheel.
Maybe im talking out of my *****you know what****** I was certain about what i was talking about as a 1/2 ton but i could be wrong that the 3/4 ton 6.0 has a spacer,im not sure now.
I bought a LQ4 out of a 04 3/4 several years ago.it didnt have a spacer but then again it may have had a manual trans behind it,cant remember.
Hey OP do you have a spacer?
