6.0 to 4l60-E
Old Aug 13, 2006 | 02:12 PM
dirt track racer 81's Avatar
Default 6.0 to 4l60-E
What's needed to bolt a 6.0 to a 4l60-E?? Isn't there some kind of spacer of some sort needed??
Old Aug 13, 2006 | 02:20 PM
thunder550's Avatar
High on diesel fumes
If the engine is 01+ all you need to do is swap your flexplate over from the 5.3
Or, if it was already bolted to a 60E then you don't need to change anything.
Old Aug 14, 2006 | 09:28 AM
so just bolt my 5.3 flexplate up and go??
Old Aug 14, 2006 | 09:41 AM
thunder550's Avatar
Yep, the spacer is generally needed when you are putting an 80E behind something that had a 60e from the factory. I had to use one when I bolted my 80E up to the LQ9. The two trannies use different flexplates. As long as your motor is 01+ it should have the same length crank as your 5.3, so you should be able to bolt up the flexplate and go.
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
Cammed4ever
Sep 30, 2015 03:38 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
