4wd front end straps
Here is where I am getting mine from.
Poly Performance JEEP/TRUCK & BUGGY :: Limit Straps - 4X4 Off-Road Parts, JK Synergy Suspension Systems, Fox Racing Shox, Beard, CNC Brakes, Johnny Joints®, Currie Enterprises, Edelbrock, Pit Bull Tires, Ramsey Winch, ARB, Walker Evans, Wilwood, Mast
One of our sponsors, PM them about a package deal if you are interested.
11" Would probably be just right for mine with the clevis at the top of its threads at full extension, but the 12" is fine. When I move the nuts down on the pin I should have about an inch of thread left with the truck at level height. Total travel of the front is around 3-4" I think. I leave them completely slack while just driving around. I havent tested them yet, but I dont expect them to stretch much given the expected load on the front end.
My clevis pins have 4" of thread, which is the standard from what I could tell.
Well if they have 4" of thread I may want 11", mine is only lowered slightly in the front. I also jacked mine up and even at full extension the length of the shock from bolt to bolt only changed by 1". 11" should put me at about center of threads when static. Thanks for the info Richard.
11 Second Hall Moniter
I ordered 10" straps. Spoke with Taylor about these for a while, very helpful guy. He told me to expect them to stretch about an inch per foot, so I factored that into the length that I chose. The bolts are 5 or so inches long, so I'll run them loose for every day driving, then cinch them up at the track.
I'll probably crank them down just enough to barely begin to lower the front end, if that makes sense. Then I'll try a pass with a little preload, and see what happens. Maybe some mid 1.5's for a short time? Who knows.
