4L80e yoke to lose
hey guys im doin a 4l80e swap in my 2001 ecsb and I ordered me a yoke part# n3r-3-9161x when I install it, it seems to me its a lot loser than it should be. Isnt it supposed to be firm and snug when you slide it onto the shaft? or is this normal? also when I rotate it back and forth a little I can feel its got some play.
yes splines are all the way in, its not the bushing because I had the tailhousing off to make sure the shaft wasn't moving its got play between the shaft and slip yoke, I thought it was suppose to fit very snug its like the slip yoke is just a touch big
O ok i see what your saying now. The inside splines seem to.be a lil sloppy loose when on the output shaft of trans? Maybe a bad yoke. I order mine off ebay. I get th longest one and cut 1" off the end with.a chop saw. Works for me.
jscherbs
Sep 30, 2015 07:54 AM
