4L80E Where do you take temp readnig (aftermarket sending unit)
Old Jul 18, 2013 | 12:47 PM
BigHate's Avatar
But with it in the pan or return line you are getting a static reading before the the pump sucks it up through the filter and the cycle begins. If the fluid is getting too hot somewhere between the filter and the cooler outlet something is malfunctioning and hot trans temps are a result of that.
Old Jul 22, 2013 | 07:42 AM
spent21's Avatar
Originally Posted by BigHate
...If the fluid is getting too hot somewhere between the filter and the cooler outlet something is malfunctioning and hot trans temps are a result of that.
the fluid heats up regardless of a problem between the filter and the cooler. Do you even know what a transmission is or what it does?
But with it in the pan or return line you are getting a static reading before the the pump...
What exactly is a 'static reading'?
Nevermind... put the damn things wherever you want them.
Old Jul 23, 2013 | 09:21 AM
BigHate's Avatar
Calm down there little guy it's gonna be okay
Old Jul 23, 2013 | 02:34 PM
Suburbazine's Avatar
I dunno, that post had a lot of fail from a transmission guru's point of view.
ullose272
Aug 5, 2016 02:05 PM
Zacholcomb
Sep 3, 2015 06:14 PM
Gadgetized
Jul 22, 2015 11:55 AM
SumtinCoo
Jul 16, 2015 10:40 AM
