4l80e trans brake
Old Apr 16, 2016 | 08:08 PM
custm2500's Avatar
Ph.D. in HUBRIS
Default 4l80e trans brake
Sorry search never works on my phone, but don't remeber any info.
To add a brake to my 80e I need a valve body, and a reverse patern shifter? With the valve body come with the brake or is that sepperate? Can I use the factory colum shift or is an aftermarket a must?
Old Apr 16, 2016 | 08:15 PM
George C....'s Avatar
Formerly ScreamingL
you can do the hack mod and pay a visit to sloppy mechanics page as they do a wiring trick to fool the 80 into a transbrake should be right up your alley for being a butcher
Old Apr 16, 2016 | 09:50 PM
custm2500's Avatar
Ph.D. in HUBRIS
Might give it a shot but I was going to have the trans gone through and possibly add a brake if it wasn't too costly.
Old Apr 16, 2016 | 10:08 PM
Formerly ScreamingL
Best have good internals for a brake
Old Apr 17, 2016 | 01:21 AM
1FastBrick's Avatar
Custm2500's Rude Friend
Look up Jake's Performance. He offers 2 different Trans brakes for the 4L80E.
I am in no way recommending them, merely just pointing out that he sells them.
Old Apr 17, 2016 | 08:40 AM
custm2500's Avatar
Ph.D. in HUBRIS
This 80 is going in a fairmont. It weighs right at 3000 right now qith a nitrous 4.8 but the 76mm turbo will go on later. I think the trans needs done anyhow, so was considering doing the brake now. Do I need upgraded internals for a 3000 lb car with 400 or so hp on nitrous?
I didn't have time yet to look up the sloppy mechanics trickery does it have some decent results?
Old Apr 17, 2016 | 08:42 AM
Formerly ScreamingL
Brake is gonna break ****
Old Apr 17, 2016 | 11:32 AM
custm2500's Avatar
Ph.D. in HUBRIS
Gotcha. If I could put a brake in for $300- $500 I was considering doing it now, I will just wait till I put the turbo on and plan to bullet proof the 80 then.
I am not bracket racing or anything now anyhow, just looking to have some fun.
Old Apr 17, 2016 | 11:42 AM
1FastBrick's Avatar
What happened to the truck???
Old Apr 20, 2016 | 10:36 PM
custm2500's Avatar
Ph.D. in HUBRIS
I bought this and going to put the 4.8 and turbo in it.
Either go stockish 6.0 or diesel swap the hd with tucked semi wheels, 13" out back and 8" up from tucked. Narrowed backhalfed so the meats will fit. Putting 325/50r22s on the semi wheels out back.
Size:  338.2 KBName:  20160414_204546.jpg
