4l80e temperature climbing T/275deg
I just bought a 06 2500hd & the temperature gauges slowly climbs to 275deg, but the trans cooler is not getting warm.
I've checked for kinked lines & I bypass the radiator & it still climbs to 275. The fluid is still nice & clean. Could it be the gauge or the filter getting plugged up? I dont know how the pumping system works for the cooler. |
Id start with pulling a line off the cooler and start it for a sec and see if its pumping fluid..
Could be the gauge i guess but doing the above would rule out a blocked line :) |
If a line would be stopped up or it's not pumping fluid, what would I need to do too fix it?
Id pull the whole line if that happens and see if clogged..
I just pulled feed line to the cooler & it's pumping. Then I pulled the return line to the trans @ the trans & it's pumping fluid all the way around.
Guess I need a temp gun. |
Possible bad temp sensor/sending unit?
Thats odd its reading that. |
Put a scanner on it to verify the sensor (HPTuners or EFILive).
I should have brought it with me. I tried a brake stall tonight & it's 2200rpm. is that normal for the 80.
Yeah that's about what it should be. Get a heat gun and shoot the pan and see if it's really that hot.
If it's not I'd replace the trans temp sensor and interal wiring harness. |
Thanks.. Once I get home I can try my cluster out the race truck lol. I talked with frank he said if I drove 500 plus miles @ 275 the fluid would be black & it probably wouldn't make it 500 miles
