4L80E swap..Questions
Old Mar 24, 2015 | 12:26 AM
Wrecker 426's Avatar
Default 4L80E swap..Questions
Think i have it figured out but have a few questions, and yes i know there is a search function but after hours of search, yes i still have questions.
Burnt out the 3-4 on a 60e so I will be swapping and dont want it down for more then a weekend as a dd, since i can make it to work and back on two gears
This is what I have found i need:
FLT 4L80E-4...Still wondering if i should get the billet input or not, info/input would help
15765623 Cover - bellhousing
15832205 Tube - dip stick tube
15183801 Indicator - dip stick
15013290 Bracket - shifter cable, Also be running a winters gate shifter so that covers the cable
6.0 Flexplate/spacer and TC bolts
32 spline T-case input shaft, new main seals
Tcase to xmsn adapter? don't know if FLT ships it with it
yank multidisk 3000 stall
Cross-member mod
Wiring harness from speartech
Tune I already got from BB
True cool oil cooler and brackets from Time2Kill,
Just need to figure out the line extension back at the xmsn
Dont see the rear drive-shaft being an issue with the lift
Main info links iv already read, to many to quote them all:
LS1 Truck
KySilverado
Am I missing something or am i on track?
And thanks for the smartass answers in advanced
Old Mar 24, 2015 | 03:29 AM
natejk's Avatar
8 Second Truck Club
i got my crossmember from dirttrackracer made the install a piece of cake if your getting a converter made they can make it for your 60e flexplate you just need a 4l80e hub and 4l60e pilot side,as for line extensions they make tube to AN fitttings http://www.summitracing.com/parts/su...077b/overview/ they work awesome or you can AN line the whoole thing thats what i did
Old Mar 24, 2015 | 05:23 AM
You got picture or a write up on that? never built lines before. Running new full lines sounds nice. Also would i have to cut and flare the hardline to use that?
As for the TC it shouldn't be to hard to change the flex plate out, and its just one of those piece of mind things with the six vs three bolts back there.
Old Mar 27, 2015 | 12:19 AM
natejk's Avatar
8 Second Truck Club
I don't have a write up I just sold a 80e plate bolts and spacer I'm using the 60e with arp hardware making lines is simple and no you do not need a flare tool for the hardliners if you use those fittings there syoutube videos for them
Old Mar 27, 2015 | 12:40 AM
natejk's Avatar
8 Second Truck Club
Braided Hose Assembly with AN Fittings - Summit Racing Quick Flicks:
Old Mar 27, 2015 | 01:02 AM
natejk's Avatar
8 Second Truck Club
Converting hard tube lines to AN fittings the easy way:
Old Mar 27, 2015 | 01:05 AM
natejk's Avatar
8 Second Truck Club
I used these instead of the hard line and did AN LINE TO MY COOLER http://m.ebay.com/itm/like/230791392105?lpid=82&chn=ps&ul_ref=http%253A%252F%252Frover.ebay.com%253A80%252Frover%252F1%252F711-117182-37290-0%252F2%253Fmtid%253D1588%2526kwid%253D1%2526crlp%253D69982082769_324272%2526itemid%253D230791392105%2526targetid%253D124340441769%2526rpc%253D0.20%2526rpc_upld_id%253D45925%2526rlsatarget%253D%2526device%253Dm%2526mpre%253Dhttp%25253A%25252F%25252Fwww.ebay.com%25252Fitm%25252Flike%25252F230791392105%25253Flpid%25253D82%252526chn%25253Dps%2526adtype%253Dpla%2526gclid%253DCNW40LPux8QCFTBo7AodezcA9w%2526srcrot%253D711-117182-37290-0&ul_ref=http%3A%2F%2Frover.ebay.com%3A80%2Frover%2F1%2F711-117182-37290-0%2F2%3Fmtid%3D1588%26kwid%3D1%26crlp%3D69982082769_324272%26itemid%3D230791392105%26targetid%3D124340441769%26rpc%3D0.20%26rpc_upld_id%3D45925%26rlsatarget%3D%26device%3Dm%26mpre%3Dhttp%253A%252F%252Fwww.ebay.com%252Fitm%252Flike%252F230791392105%253Flpid%253D82%2526chn%253Dps%26adtype%3Dpla%26gclid%3DCNW40LPux8QCFTBo7AodezcA9w%26srcrot%3D711-117182-37290-0
Old Mar 27, 2015 | 01:07 AM
natejk's Avatar
8 Second Truck Club
I'll get some pics this weekend
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
RustyD
May 23, 2016 07:04 PM
AdaMax
May 16, 2016 11:35 PM
turbo6c3
Oct 5, 2015 06:11 PM
jscherbs
Sep 30, 2015 07:54 AM
